bmlawrence4
Yes...Wish I seen this earlier. I started getting the warning on my 2019 2500 Laramie about 3 months after I took delivery in March 2020. It interfered with a lot of other systems as well. The radio would cut in out and in...driver and passenger windows would work intermittently...my heated/ventilated seats would not work etc and my surround camera was not working to name a few. It got so bad while waiting for my appointment that it did nothing but ding every 30 seconds. Finally was able to take it in, after 4 days of troubleshooting they found a bad module in the drivers door. Replaced the module and all was good until last week when the symptoms came back. Same warning with similar issues. radio, windows, heated seats camera not working etc... I have yet another appointment to have them look at it again. It is becoming an aggravating issue at this point.Has anyone seen/gotten/serviced the alert: Blind Spot Alert Unavailable Service Required? It comes and goes with no real rhyme or reason??
Jersey walls shouldn't activate a warning and if you got a message on your info screen than it was probably what I experienced. It starts out very intermittent and worsens over time. I took my 2019 Ram into the dealer 21 Oct. for the second time. Again they tech downloaded 27 pages of codes that were saved in the computer. Now they are talking to engineers at Chrysler and a lead mechanic for the region. They think at this point, it may be a bad wire bundle that was installed in many 2019 and 2020 ram trucks. I will try and keep this thread posted as I get information. Keep and eye on your information panel. If it worsens and other things like heated.cooled seats are inop, radio cuts out and in front driver/passenger windows work intermittently are examples of further degradation. If so, take it into your dealer and have them look into it. So glad I bought the extended warranty with this truck. Good luck.
Wow...well, if you are still under warranty and it continues, suggest they download your fault codes. This anomaly isn't easy to simply "duplicate" but will leave a sheet of faults showing that there is and issue. Good luckI had this error, along with “power running boards - service required”. I got the dealer “we can’t repeat it excuse” even after I showed them video of the error. I gave up, the error only occasionally shows up now.… I made it my friend.
Been a while since I posted. So just to update in case you are curious. On my third visit, the dealership, after 3 weeks of trouble shooting, determined it was the radio causing my problems. They replaced the radio and I picked it up the next day. Exactly 2 days later....Ding ding ding, blind spot unavailable service required. everything controlled through the radio was turned off or intermittent. Windows would not work either. Sitting in my driveway totally pissed at this moment and wondering how I can sue for this; I opened my door with the engine running. As luck would have it, the chime stopped, my controls worked on the radio and the windows went up and down. Shut the door and the warning returned., I did this a few times, wiggled the wire harness going from my door to the chassis. Silencio for about a week. When it returned, I repeated my efforts 2 more times than video recorded what was happening on the third event. I went in and showed the service manager and mechanic. He took the truck back in and studied the harness. They found 2 pins in a connector that were loose enough to fit sloppy in the connector. They actually duplicated the problem. They have ordered me a new harness and will install on Monday. Hopefully I have stumbled across my ghost and this will fix the issue I have chased for 14 months. Boils down to...a blind dog finding a bone I guess. Even the mechanic said, while shooting wires, he never moved the door from its full open position. What he also said was, the door modules, both left and right, were showing the doors open all the time.Wow...well, if you are still under warranty and it continues, suggest they download your fault codes. This anomaly isn't easy to simply "duplicate" but will leave a sheet of faults showing that there is and issue. Good luck
Thanks for the updates. I'm having BSM issues as well. The dealer opened a Star Case and they decided to replace the module (hoping this fixes it). The module was on backorder, but is supposed to be in next week. Hopefully that does the trick.Been a while since I posted. So just to update in case you are curious. On my third visit, the dealership, after 3 weeks of trouble shooting, determined it was the radio causing my problems. They replaced the radio and I picked it up the next day. Exactly 2 days later....Ding ding ding, blind spot unavailable service required. everything controlled through the radio was turned off or intermittent. Windows would not work either. Sitting in my driveway totally pissed at this moment and wondering how I can sue for this; I opened my door with the engine running. As luck would have it, the chime stopped, my controls worked on the radio and the windows went up and down. Shut the door and the warning returned., I did this a few times, wiggled the wire harness going from my door to the chassis. Silencio for about a week. When it returned, I repeated my efforts 2 more times than video recorded what was happening on the third event. I went in and showed the service manager and mechanic. He took the truck back in and studied the harness. They found 2 pins in a connector that were loose enough to fit sloppy in the connector. They actually duplicated the problem. They have ordered me a new harness and will install on Monday. Hopefully I have stumbled across my ghost and this will fix the issue I have chased for 14 months. Boils down to...a blind dog finding a bone I guess. Even the mechanic said, while shooting wires, he never moved the door from its full open position. What he also said was, the door modules, both left and right, were showing the doors open all the time.
My BSM issue was finally resolved when they found that the rear wiring harness was shorting out somewhere along the way. So they overlayed new wires and I haven't had an issue since. Your issue sounds pretty similar to mine, except the areas affected is different. I'd suggest they look at replacing the wiring as it may be what's making the modules go bad.Yes...Wish I seen this earlier. I started getting the warning on my 2019 2500 Laramie about 3 months after I took delivery in March 2020. It interfered with a lot of other systems as well. The radio would cut in out and in...driver and passenger windows would work intermittently...my heated/ventilated seats would not work etc and my surround camera was not working to name a few. It got so bad while waiting for my appointment that it did nothing but ding every 30 seconds. Finally was able to take it in, after 4 days of troubleshooting they found a bad module in the drivers door. Replaced the module and all was good until last week when the symptoms came back. Same warning with similar issues. radio, windows, heated seats camera not working etc... I have yet another appointment to have them look at it again. It is becoming an aggravating issue at this point.
Here it is, 2022 and my RAM is doing it also. You think they'll would have figured it out by now. The service department took my dash apart and replaced two modules, thinking they were the problem. My daughter picked it up and was driving it home and...you guessed it, it came back...again. Has anybody received a recall for this problem?Yes...Wish I seen this earlier. I started getting the warning on my 2019 2500 Laramie about 3 months after I took delivery in March 2020. It interfered with a lot of other systems as well. The radio would cut in out and in...driver and passenger windows would work intermittently...my heated/ventilated seats would not work etc and my surround camera was not working to name a few. It got so bad while waiting for my appointment that it did nothing but ding every 30 seconds. Finally was able to take it in, after 4 days of troubleshooting they found a bad module in the drivers door. Replaced the module and all was good until last week when the symptoms came back. Same warning with similar issues. radio, windows, heated seats camera not working etc... I have yet another appointment to have them look at it again. It is becoming an aggravating issue at this point.
Have you gone to FCA directly for answers to your problem. I just finished up a letter asking what they are planning to do for us.Dealer never figured out the issue on my truck. It went away, came back and bugged the **** out of me for a week before going away again. About 3 weeks ago, it started. On one frustrating commute of 60 miles, I think it went off the entire time. Today was the first day in this episode that I drove the truck without that damn warning beep beep beep going off.
