NightTrain
Say it isn't so! SWIFT - Sure Wish I Finished TrainingYes, that is the only one they use for Saltillo
Indeed, in this case though it should be a sure thing since there is a window sticker too.Be careful...i had an EL before mine went to the vendor for spray in bedliner...and it is listed on my EL.
I should clarify...there can be items added to the truck after the EL is populated...the vendor installed items. But, I also would agree that when it goes KZ it should be complete.
Yes to both.Does this mean it's still waiting to get on a train, or could this also mean it's already on it's way?
Thank you! I just sent an email to the dealer to see if they can get an updated code. So, trying to understand the various KZ statuses. Is first rail the train from Mexico to the US? Then 2nd is from somewhere in the US to it's final train yard where it gets unloaded?Yes to both.
Dealer had no way to track mine on the way in other than a code change indicating first and second rail. Even then that lagged behind reality by about a day.
KZM = Kan Zee MovementCorrect, first train out of Mexico is KZM, all others are KZT
I hope I go KZM soon!!KZM = Kan Zee Movement
Same. I'm stuck somewhere between equipment listing and window sticker. Not sure what status that is, but guessing JS.I hope I go KZM soon!!
Right there with you! I'm about to look up how-to videos on summing a train at this rate!I hope I go KZM soon!!
On Order: Ordered 02/17/22 - 2022 2500 LARAMIE CREW CAB 4X4 (149 in WB 6FT 4 IN box) 2500 LARAMIE CREW CAB 4X4 (149 in WB 6FT 4 IN box) 6.7L I6 Cummins Turbo Diesel Engine Granite Crystal Met. Clear Coat Laramie Level A Equipment Group 2 Tow-Mode Digital RR View Mirror Pkg Night Edition Off Road Package Blind Spot and Cross Path Detection Bed Utility Group Uconnect 5 Nav w 8.4" Display (USA) Towing Technology Group B Flat Cab-Length Side Steps Painted
Yes as far as ramchat goes. Sandi may not have better info since the dealer tracking side of the system is down. Ask her for the current status codeDoes this seem right?
Must have been on same delivery truck to Mark Dodge!Truck has been delivered to Mark Dodge.... Now just paperwork, payment and getting it shipped.
I'm in AGGood ol Pismo Beach!
Mine is at Mark Dodge today!! Now to get there and picked up!
