gimmie11s
^I wonder if switching to a dual rear wheel rig contributes to your lower than normal mileage on the diesel. It seems like you are getting around 3mpg lower than what most folks report. Your hemi also seems to get better than typical mileage... I typically hear numbers of 11 to 14.
Not many will get 11-14 towing a RV load over 12k lbs. .... I could care less what they type online--it aint happening.
I get 8-9 towing my 5er with a DRW HO cummins truck... trailer is about 13k lbs loaded down with toys.
That Ford 7.3 is THE engine to get if you want a gas truck.. stay away from Ram or Chevy. That 7.3 is a beast and backed up by a 10sp trans that will ALWAYS keep the gas motor in its power band.
That said, if you plan to tow more than 10k lbs, or a 5th wheel--I'd never buy a gas truck. Pulling hills/grades or towing in elevation will be miserable compared to any of the big 3's diesel offerings.
