Hey guys, thanks for the info on the fog lamps. I am looking forward to adding these to my tradesman as well. One question.
@elephantrider
@Compshooter
What did you use for a connector/ harness to the bulb? Was it anything unique or special? Pictures from the backside would be awesome if possible.
It looks great and I would like to do the same. Could you please send a list of part numbers including both lights, any bezels and brackets. Thanks!Factory fog lights installed. Thanks to elephantrider for the part numbers. The dealer was no help at all. Wired them to up fitter switch #1 . Used a relay even though I really didn’t need to.
I just got my 2020 Tradesman, I put the OEM LED fog lights in the bumper, I have two OEM connectors for the LED lights and no idea how to wire. The fog lamps each have a four wire connector? would you by chance have a schematic on the wiring?I added factory fogs and wired them to a switch so I could have high beams and fogs simultaneously.
I had the dealer install the factory brake controller with no issues.
I’m going to wire these into my upfit switch panel, which looks a bit intimidating, but first question, just connect the blacks together from R-L and ground to the frame, then connect the other word together and run them to the switch block?
Those will be $3.99/ea. Thank you, FCA.Does anyone know the part number for the screws that are used to mount the actual fog light to the bracket. I ordered the lights, brackets and bezels.....the screws were not included.
Hahaha....I didn't find $3.99 that surprising. So I went looking around online and was pleasantly surprised to find them for $0.63.Those will be $3.99/ea. Thank you, FCA.Typical these days where everything is a purchase item.
You do not have to go to the switch, there is a port on the firewall. You use the wire accessory kit that came with truck, if outfitted with aux switches.I just ordered all the parts (I think - bezel, bracket, hardware) to install fog lights on my Tradesman (when it arrives - just placed an order) minus the actual fog lamp. I intend to install the Baja Designs Fog Pocket kit (see link below) and need a little help with getting these wired up. I want to control the fog lights from one of the factory installed auxiliary switches I ordered with the truck. From reading on here and other forums, it sounds like I need some sort of harness to get from the fog lights to the auxiliary switch, right? I have no idea what materials I need to make this happen. Do I need a fuse? Relay? I'm pretty ignorant when it comes to the electrical side of things so forgive me if I'm way off.
Also, any opinion on SAE vs non-SAE lights?
Baja Designs
Baja Designs offers high performance LED lights and light bars for off road trucks, UTVs, and ATVs. Baja Designs is The Scientists of Lighting, contact us today for more info!www.bajadesigns.com
Pretty sure each aux switch has its own fuse and relay, they are located in the little fuse box next to where you connect the wires on the drivers side firewall under the hood. It’s a apiece of cake.I just ordered all the parts (I think - bezel, bracket, hardware) to install fog lights on my Tradesman (when it arrives - just placed an order) minus the actual fog lamp. I intend to install the Baja Designs Fog Pocket kit (see link below) and need a little help with getting these wired up. I want to control the fog lights from one of the factory installed auxiliary switches I ordered with the truck. From reading on here and other forums, it sounds like I need some sort of harness to get from the fog lights to the auxiliary switch, right? I have no idea what materials I need to make this happen. Do I need a fuse? Relay? I'm pretty ignorant when it comes to the electrical side of things so forgive me if I'm way off.
Baja Designs
