My rig; 2022 2500 Limited Mega Cab CTD
Texasram1
Barely any mods yet but got it tinted, put the weathertech vents and floor liners in, and the console vault.
My Revolver X4s arrived this AM and I just installed it. This is my 3rd revolver, so install was a breeze.
Hung the v1 on a blendmount today, and wired it and my dashcam to ign power thanks to @Brutal_HO
Next up, BMP rear CAT filter kit install which arrived today.
EDIT: i have the factory aux buttons, so I plugged the grey pigtail that came with the kit into the harness under the dash by the parking brake. I then tapped one of the looped wires for IGN power. The other looped wire is +12V constant. Then I connected an eye terminal to a bolt under there for my ground. Then tan power and ground up the A pillar and across the top if the dash.
Reposting pics here to keep the evolution of my truck in one place
UPS is finally delivering what I need to get going
Started taking out the storage bin, factory sub and flaps. 4 1/2” nuts for the flaps, and 3 10mm nuts for the bin.
Im not sure what to do with the storage bin mounting studs. Looks like they have to be cut off, but I’d like to find a way to remove them and reinstall them later should I want to.
Cut the studs off. Box fits like a glove. Plenty of speaker clearance with the seat upright or fully reclined.
Good thread!! Yours is my Cummins twin. Can’t wait to see sub setup once your finished.
I’m going to use aux6 to be able to turn the amplifier on/off, so I wired it to the pass-thru and will pick up the lead inside the cab.
Wired the box with some proper gauge wire, and did it to net a 2ohm load.
I could not get the aux connector bracket off the fuse box, so I took the aux connectors of their bracket. Got the power and remote turn ons run to the back of the cab.
I will cover the power wire under the hood w split loom as soon as it gets delivered.
Slowly pecking away at it.
The amphenol connector to grab the stock sub signal is all I’m waiting on before I can button it up.
