Have you tried backing off the plastic bolts that the hood rests on? there's usually 2 large threaded plastic studs to the left and right of the grill that you can raise or lower. Raising those up might help remove some of the play in your hood.
I've had to do this on other vehicles, but haven't had any issue on this truck.
checking that out. many thanks there!
Have a question, I just travel from AZ to Oklahoma, 16hrs, 1060 miles. I was averaging 17mpg before I hit 40mph crosswinds. I went to multiple truck stops looking for DEF, they only had the big nozzles, what does everyone use when they come across that? I ended up buy a box of DEF. Truck looks good on the ranch. Also the truck did better on fuel at 85mph then 75mph
View attachment 33872View attachment 33873View attachment 33874
My cruise control maxes out at 85mph, how did you get your to go higher?
Info on this, please. Never seen that before.
The MOLLE panel is from Putco. It's one of the few that tucks under the bed cap ledge. It also one of the few that doesn't require drilling any holes into the sheet metal to install. It uses the tie down cleats to mount. I did have to modify the front bracket it comes with to fit with my diamond back toolbox in the front.
Looking at it, do you think 255/85/17s would rub? How’s the gap between the duallys? I think this is the route I’m going.
I'd have to look at the 85 dimensions but I'm going to add a 1/4" spacer between the wheels just for a tiny bit extra since I tow decently heavy....
So it looks like they are the same width just taller....should be fine....
Awesome. Was wondering if the larger circumference would cause issues. Think that’s the way I’ll be going.
Just did some digging....they don't appear to be made in a 17" wheel....only 16"....
