Light Bar Install
Looks great!
Connect thru a switch or did you wire into the high beams?
Wow! That looks AWESOME! Do you have part numbers/info one the products you used? Be interested to do something similar . Thanks!
Thanks! I was pretty pleased with how it turned out.
Links:
30" LED Bar
4" LED Pods
3 Metric Ton Tow Hooks
Side supports - 1/4" x 2" x 2" A500/A513 Tube
Cross support - 1/8" x 2" x 1" A36 Tube
Probably a little overkill on the side supports, but I didn't want to worry about rigidity with the relocated tow hook location.
Links:
30" LED Bar
4" LED Pods
Thanks for the info!
Does it interfere with sensors on front at all?
