Fishspike
Did you order a kit to do this?PPF on front/rear bumper, grill, and door cups. Wasn’t sure how it would do on the blue in dark and bright light. Looks pretty good so far. Might get the hood later too.
Where did you get the PPF? Was it bad to put on because I want to do my grill area and hood.PPF on front/rear bumper, grill, and door cups. Wasn’t sure how it would do on the blue in dark and bright light. Looks pretty good so far. Might get the hood later too.
I was too chicken to do it myself. Went here:Where did you get the PPF? Was it bad to put on because I want to do my grill area and hood.
Nice. Looks like aluminum extrusion with forged aluminum pieces.Installed Leitner ACS Forged Rack today, the Master Chief approves. If you need a rack second to none with tons of options look no further. They just started shipping the unit for 8 foot bed…
I did the front and rear on my 18 loved that setup,I'll be doing it again when I get my new truck.Converted the rear filter....doing some more digging before I do the front unit but it's an easy task....and now the filter is even easier to change....I opted for the spin on heater element to keep my dizzel warm and toasty....
I like the DeeZeeLooking to get an 8’ rubber bed mat. I want something precut that all the corners line up perfect. Thick rubber. Any suggestions
Even with my lineX everything still rolls around
Is that a dual ARB pump in there?
It is indeed.Is that a dual ARB pump in there?
Man, I would forget that was there until the first time I went in a parking garage.Installed my new Rearview Mirror Camera Mount so I can see into the boats I haul.
I removed a screw in my tire and finally got around to installing the KC Cyclone hood lights I received Christmas before last. Lucked out with the screw. It went in at an angle and it didn't leak.
Screws work great in wood and sheet metal but suck in tires.Purpose?
Finally warm enough to get a first wash and ceramic wax done...
Do those have an automatic switch or manual? Just asking cause I’d leave mine on by accident all the time and drain the battery.I removed a screw in my tire and finally got around to installing the KC Cyclone hood lights I received Christmas before last. Lucked out with the screw. It went in at an angle and it didn't leak.
