PPF on front/rear bumper, grill, and door cups. Wasn’t sure how it would do on the blue in dark and bright light. Looks pretty good so far. Might get the hood later too.
Where did you get the PPF? Was it bad to put on because I want to do my grill area and hood.
I was too chicken to do it myself. Went here:
Their AZ location, not Cali. Bob Moses ceramic coating recommended them. $900, but think it’ll be worth it.
Installed Leitner ACS Forged Rack today, the Master Chief approves. If you need a rack second to none with tons of options look no further. They just started shipping the unit for 8 foot bed…
Nice. Looks like aluminum extrusion with forged aluminum pieces.
Looking to get an 8’ rubber bed mat. I want something precut that all the corners line up perfect. Thick rubber. Any suggestions
Even with my lineX everything still rolls around
Converted the rear filter....doing some more digging before I do the front unit but it's an easy task....and now the filter is even easier to change....I opted for the spin on heater element to keep my dizzel warm and toasty....
I did the front and rear on my 18 loved that setup,I'll be doing it again when I get my new truck.
Gave her an early Spring cleaning. Didn’t have time for wax, but weather was too good not to do anything.
Finally warm enough to get a first wash and ceramic wax done...
I removed a screw in my tire and finally got around to installing the KC Cyclone hood lights I received Christmas before last. Lucked out with the screw. It went in at an angle and it didn't leak.
Do those have an automatic switch or manual? Just asking cause I’d leave mine on by accident all the time and drain the battery.
Swapped out my bed cover with my 4th gen 1500, I had the Extang Trifecta 2.0 toolbox cover for the 8’ bed on my 2500. Unfortunately an 8’ bed with a toolbox only gives you just over 6’ of full usable bed and a tr-fold cover takes that down to under 4’ unless you completely remove the cover… I had a roll up cover on my 1500 with the 6.5’ bed and it was only a 1/2” longer, ended up working perfect for both trucks (I don’t haul anything with the 1500). Now I still have 6’ of usable bed space on my 2500 with the cover rolled up.
I’ve come to like having the roll up cover with my toolbox. This is first truck I’ve put one on and the added dry space when traveling or grocery store runs is handy.
