aaronedmonton
Disclaimer: Tried the search function, it sucks.
Now on to my current situation:
Truck:
2021 Ram 2500 Tradesman 4x4 6.4L Hemi - Otherwise stock besides below
I recently purchased 18x9 American Racing wheels with some LT35x12.50R18 Hercules AT-X Venture tires, as well as 2in front spacer lift.
I have been driving it recently and noticed the back end very slightly pulling to the right (with the pitch of the road.) The front seems to stay straight, with the back end coming out to the right a slight bit. It is pretty slight in most areas. I have an intense human gyrometer so I feel it when it feels like it's crabwalking.
Now this happens mostly with the pitch of the road and only the rear end "feels" like it's moving. I do have to hold the steering wheel slightly to the left to counteract the pull. Tire pressure is at 65 all around on these A/T tires. Might be slightly high. It doesn't seem to crabwalk with a trailer.
I took it back to the shop to ensure everything is setup correctly. They said it all looks good, and that RAMs have some issues with heavier tires. Rear tires were swapped from left to right to ensure good tires still. I know from experience with my dad's Ram 2500 that had Toyo M/Ts, it would pull right but the whole truck, not just the rear (again, subjective feeling.) With my dad's truck, we installed that upper steering stabilizer and it corrected the right pull.
When I very gently flick the steering either direction, the back end sways quite a bit. Didn't notice this with stock tires and wheels. Why does it sway so much?! Could be the coil springs? There is no extra movement vertically, only horizontally.
Some questions so far to start:
Do I need an Upper Steering Stabilizer? Doesn't seem to be an issue with the front and there shouldn't be much adjustment in the rear, if any.
Do I need an aftermarket track bar? (Left and right sides look identical, not really moved towards one side after level)
Do I need to lower tire pressure to 50 unloaded?
Do I need a stiffer/better rear sway bar to handle the extra weight in wheels and tires?
Just looking for a direction to head in if I want to correct this.
Truck:
