Um, unless I missed something big you shouldn't be due for a trans oil change and filter for a while.Approaching 30k miles soon.
What are u guys using for tranny oil and how many quarts does it need?
Thanks in advance.
T
Aisen trans: ASRC fluid
My parts department guy told me Mobil 3309 is the equivalent. He also said drain and fill is 7.2qts and the overhaul/filter change is 13.74qts. When he looked up the Mopar fluid in the computer it listed the fluid spec. as JWS 3309.
3309 is ASRC..I have spoke to Aisin on this, If you have 4x4 you will need to loosen the Transmission cross member bolts and raise the rear 1.1/4" to remove the rear pan bolts to change the filter, the 69 filter is entirely different then the 68. Yep you will be pissed when you see the rear pan bolts within 1/2" of the cross member.
Max temp 266 deg. F trips warning light
klmperformance.com
This is the kit a buddy of mine who works in a diesel shop said they order all the time.![]()
Mopar Aisin AS69RC 6 Speed Transmission Service Kit 13-22 Dodge Ram
MOPAR Aisin AS69RC 6 Speed Automatic Transmission Service Kit has the Mopar Transmission Oil Sump Filter, Mopar Transmission Pan Gasket, and Twelve Quarts Of Mobil 1 3309 or MOPAR ATF+4 Synthetic Aisin Automatic Transmission Fluid For the 2013 to 2022 Dodge Ram Cab and Chassis 3500, 3400, and...klmperformance.com
Neither one of those is the right fluid for the Aisin. Search for Mobil 3309. Pretty hard to find locally, you'll probably have to order it.Mobile 1 ATF
Or
Mobile 1 atf+4 synthetic? Fluid option
Thnx
The oil isn't right.. he said it comes with a moble atf 3309.Mobile 1 ATF
Or
Thnx
I just hope you weren't disappointed.The internet has ruined me …..
Thought this post was about something completely different haha
