Questions that came up while trying to order a 3500 SRW
jebruns
Trying to put together an order for a 3500 CTD SRW. I've figured most of it out, but need help with a few questions.
-Is there a bigger fuel tank option for the 3500? I thought there was, but it does not come up on the build sheet. Dually only option?
-Is the Filigree leather just the extra stitched in design? Same leather otherwise?
-The Longhorn Limited prices out more than the Limited with the same options. Is the LL considered the premier truck in the Ram lineup? What does it have that the Limited does not? Or vice versa?
-Not a big fan of the purse flaps on the back of the seats on the LL and Limited. Can those be removed?
-If I don't get two tone paint, painted bumpers or the night package, the bumper is chrome on the LL and Limited, correct?
Thanks
The limited has more of the options in packages. The Longhorn with the same options have some of the options listed indiviually. Since the packages are somewhat cheaper over the individual items, a Longhorn can be more expensive. My 2021 Longhorn was 600 dollars more than the Limited with identical options. I chose the Longhorn for its distinctive grill and I liked the interior better even though it was a bit more money.
The "saddlebags" on the back of the front seats are stitched on. I guess you could remove them but you will likely leave a mess.
Thanks for the info. And I misspoke above. The model between the Laramie and the Limited is not a Laramie Limited, but a Longhorn Limited. I will correct that.
It used to be called the Laramie Longhorn. Not sure when that changed.
Firstly, the two trim levels are:
Limited
Limited Longhorn
CCLB only option, gas or diesel. SRW or DRW. Not available on Mega.​
Limited and Limited Longhorn both have seat stitching, the Filigree option on Longhorn adds embossing. Looks like that changed and the filigree is stitched.
Yes, same high grade premium leather.​
The Limited offers more standard features and can also be had with Night Edition​
No​
Limited is Chrome bumper unless Sport or Night Edition​
Rename announced Q3 2020:
They changed the model to Limited Longhorn in 2021 model year.
Does the limited have the purse flaps on the back of the seats? I hate those and don't want those. If they are only on the Longhorn limited, then I am ok with that, will just order the Limited. If they both do, then will have to go Laramie.
No, I found out the Limited does not have those flaps. Not sure why I thought they did. They are, as you suggest, only on the Longhorn truck.
I thought about the Laramie also. My current truck is a loaded 18 2500 Laramie and I really like it. But for '22 Laramies, at least right now, I could not order some of the safety features I wanted, like Surround View. And since I also do not like the flaps, kind of down to the Limited.
