Where are the off-road pages found? (I feel this is one of those stupid questions.)
UConnect 5 non-NAV:
1). UConnect 'Vehicle' screen showing no Off Road menu tab, just Contols and Settings.
2). My version screen.
Is there another place to see the system version #? None of the version #'s on this screen match what I've seen others post, such as FCA-MY22.S23.13-PROD.
Should be under settings*system info
Or looks like your under the version for Android Auto or your phone almost...
I'm headed to a Dodge dealer tomorrow for an oil change and I'll ask them to show me the version page and why there are no Off-Road pages. I'll report back. :-)
I'm headed to a Dodge dealer tomorrow for an oil change and I'll ask them to show me the version page and why there are no Off-Road pages. I'll report back. :)
About the only thing I use from the off road pages is the accessory gauges... everything else is not useful for a dually. ...or any truck not used off road!
The off road pages only come with radios that have navigation as far as I can tell.
Hmm..is that still a $600 upgrade? I wonder if AlfaOBD would enable it without NAV?
Everything is an up charge…. I ordered my Laramie with navigation, would have been nice to not spend the extra $600, but I realized how useful it is…
I added it to my 2017 Bighorn and it was $600 thru the dealer. I think I found a guy on eBay doing it for $300 for the unlock code.
Since then it's just easier to get on the truck grub the factory.
Actually just looked at my window sticker… it was a $795 option for the 8.4 with NAV…
As of 19 you cant pay to upgrade you need to buy the actual head unit to get nav
That makes sense....and I was really only interested in the gauges page. Oh well, no loose.
You should be able to pull up the different gauges on the EVIC. I have mine in the 4 corners. Trans temp, oil temp, battery, oil pressure.
Water temp and fuel are permanent in the bigger gauges.
The problem with the gauges in the off road pages is that you cannot keep them as a favorite or short cut... You always have to access them through the off road app.
As mentioned already I just keep them up in the EVIC through the truck info section.
Thats only if he has the 7” evic though
You can get the gauge info in the evic with the smaller cluster. You can look at each individual gauge or have the main gauges up together, temp, oil temp, oil psi, trans temp.
