NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
3C6UR5CL9LG263234 I’m looking for part number for the
BEZEL. Instrument Panel. Center.​
Thank you.
Would you happen to be able to get the correct P/N for the 17" spare steel wheel for a 2022 PW? I assume it would be the same as previous years...
so the parts that 01Time is able to see only covers up to some MY21s. MY22 isnt included yet on his list of lookups.
however there are only 2 spares (4726 268 AA) and (6809 0830 AC)
designs are different and it appears they come in multiple sizes.
Thanks. I couldn't find in the catalog which one was the 17".
billet silver door handles (all of them) for 3c6tr5ej8lg213271 thanks
Hey I'm looking to see if i can get a part number the whole back cap of the jump seat with power ports out of a truck like this: 3C6UR5KL0KG619232 . Thank you.
Here's a picture of what i'm after, would prefer it with the 115v oulet though:
This is from my 2017 that I swapped console to a jump seat. The seat is from a 2019 and had the power outlet. My 17 didn't have the right harness to make the power outlet work and I also needed a spot to install my rear seat heaters. So I made my own rear plate and glued it in place of the power outlet.
I'm looking for the part numbers to get black wheel to wheel steps for a 2022 ram megacab like the ones on this truck. Vin: 3C6UR5NL6LG100599 thanks! (Vin is a 2020)
Looking for Drivers Front Door Panel and Switch for these two vin's, 3C6UR5DL6KG675477, 3C6UR5FL5KG615672.
For the MY2021:
4726268AA has sales code [WF1] -> 17" STEEL SPARE WHEEL
68090830AC has sales code [WKN] -> 18" STEEL SPARE WHEEL
Attached are the front and rear door hardware and components (including handles) for that VIN.
See attached.
See attached.
Just curious if you're able to get 2022 part numbers yet. I just purchased 2022 Ram 2500 and traveled WAY too far and paid WAY too much. Of course I didn't get nearly the options I would have had I had to patience to order. So there are things I'll be looking for. Actually I'm not even sure some of these can be done AFTER the factory.. Thanks!!
thank you unfortunately those are black handled part numbers. I want to convert to billet silver handles.
No 2022s yet... But it seems that most parts are interchangeable 2019+. Let me know what you're looking for and it can at least be a starting point. As far as I know, there are no limits as to what factory options can be added.
Do you have a VIN of a truck that has the handles you're looking for?
Here's a complete list of handles I made for the passive entry install thread on the 5thGenRams Forum. I'd you don't have a VIN with the handles you're wanting, this list should have most of what your looking for. (Just be aware that this list has the passive entry option for the front door doors).
For now I'm really looking for the instrument panel aux switch panel. When I look it up it seems like dozens of options. Then I hear I may need multiple additional things as well.
Status
