NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
Thanks. Yes, 8.4" non nav with AA. Now finding one might be an issue. I tracked down this other p/n (68453843AF) for a '22 but my guess is it really won't matter.
It does. 68453843AF is the Uconnect 5 8.4” non nav radio. If you get that, you’ll need a modified usb cable.
68467281AE is a Uconnect 4 8.4” non nav, and will be a direct swap out.
ahhhhhh.....i see grasshoppa.
so what the heck is 68428584AD :confused: just another older outdated version? I wish the descriptions for these things that I keep coming across would explain what is included, i.e. nav, non-nav, SXM...... maybe I just haven't found the right website yet (shrug).
That part number is showing only for 2019-2020. I can’t say for sure if there is really a difference or if it’ll work. Probably not, and if it was me, I wouldn’t hesitate to try it, but I’m not about to tell someone else to go ahead and get it to try out.
No worries. It's like each time I search you go down another rabbit hole and keep finding more random p/n's for things. Bam doesn't have any media/radio units available and I'm not really getting an ETA. But that was just my first inquiry. They had the other stuff though.
Alcoa wheels have metal valve stems. Steel wheels have rubber stems
So if Alcoa rim on rear outer, and steel rim on rear inner, surely u would need a valve extension fitted to the inner rubber valve to be able to inflate.the extra weight would cause those rubber valves to leak.
hate to bother you again...... how can I tell if this p/n would work 68461703AC. It's the NAV version but if all I need is a harness adapter I may consider it. It's used but out of '21. The price is killer though.
You can’t use that one, it is for a 4th gen ram 1500 classic.
Me again (sigh).....don't ask.
Please provide the passenger headlight assembly for VIN 3C6UR5CL7MG511451. Standard halogen bulbs.
Shot in the dark in case you can see 2021 parts by now. 3C6UR5DL6MG658231
Can I have the part numbers for the drivers and passenger side mirrors and the door modules please?
Steel wheels have these type extensions
Unfortunately I still only have vehicles manufactured up to Sept 2020 (does include some very early 2021s that will VIN filter). But here are the parts list if you want to manually compare the sales codes to the parts lists.
OK, try two. How about this vin, same question.
3C6UR5SL8LG192075
Thank you
Could you get me the part number for the Center console base and top side trims for this vin, I find some colour choices when I’m looking…previous owner drilled some ugly holes in it. Thanks in advance!! 3C6UR5DL4KG705303
This should have what you're looking for.
Status
