So this is the update. Picked up truck Jan 31, 2020 16:30. Spoke to tech that completed CP4 & whole fuel system repair. He stated this pump is the new CP3.3 which is a cast steel rear body. This pump is supposed to be heavier duty than standard CP3 of prior 2019. Stated these CP3.3 are used in the industrial applications of the Cummins motor. It was installed with an adapter and the pump shaft was bigger than prior CP3. Truck seems to run excellent and I do notice a different, less sound while pump is running. The recall is currently still open due to no parts availability claimed from FCA. He stated they ended the interim CP4 repair process before parts were ordered for my repair. So the updated CP3.3 and all parts were sent unknown to him. So he had to utilize the updated repair & install process. Ecm was also updated. A letter will be coming out soon to all recall customers stating parts and procedure are available. All I'll have to do is bring truck back to Tech to have a visual inspection and recall closed. Fingers crossed and hope this lasts!!!!!
