Non Tow Mirrors
BigBill1
Have a 2019 HD Big Horn... Looking to get NON Tow Mirrors to replace my Tow Mirrors. Not towing much and as hard as i tried to get use to the tow mirror (especially passenger side) its just not happening. Anyone have part numbers for non tow mirrors? Power folding.. and hopefully with lights like tow mirrors have.
UNLESS anyone know where i would be able to replace the passenger side glass to make it a more traditional view and then i wouldn't need to replace my mirrors.
Guys I really appreciate all the help in advance.
I'm not the expert, but I don't believe the OEM tradesman non-tow mirrors are power folding, nor have the lights. Is your issue with the split mirrors in each mirror assembly?
the tradesman non tow mirrors are bare bones manual everything. they should bolt up but won't have the lighting.
i found a set online that are oem non tow mirror for the heavy duty and they say that they are power fold.. the picture does verify this with the two plugs (black one and white one).
my issue is with the passenger mirror i don't like the setup or view. I like the traditional view with the " objects in mirror are closer than they appear " if i can replace just the glass in my passenger mirror to give me this view then ill be happy and wipe;dnt have tp buy anything else.. does anyone know if this is possible?
Just have a piece of mirror glass glued on top?
Where are you located. I have a set I took off my 15. Power fold, turn signals and lights.
Sent from my IN2025 using Tapatalk
I would love to have a convex mirror on the big glass of the passenger side. I thought about using one of those round stick-ons the old trucks used to have.
Below is a list of all side mirrors available for the 2019+HDs. This information is from an FCA EPC (electronic parts catalogue) so it should be pretty accurate. Maybe one of the chassis cab (DD/DF) options?
I'm not sure if the glass from the non-tow mirrors will fit into a tow mirror housing. But if you want me to get a list of available mirror glass, let me know.
D2/DJ​
DD/DF​
Part NumberSideSales CodePart NumberSideSales Code
68361474ADRightGP1, XAN68367430ACRightGYF, XAK
68361475ADLeftGP1, XAN68367431ACLeftGYF, XAK
68361476ADRightGU9, XAN, XAK68367432ACRightGU3, XAK, LFX
68361477ADLeftGU9, XAN, XAK68367433ACLeftGU3, XAK, LFX
68361478ADRightGPH, XAN, XAK68380336ADRightGYF
68361479ADLeftGPH, XAN, XAK68380337ADLeftGYF
68374942ADRightGU968380338ADRightGU3
68374943ADLeftGU968380339ADLeftGU3
68374944ADRightGPH68381772ADRightGPG
68374945ADLeftGPH68381773ADLeftGPG
68374946ADRightGU9, XAN68412768ACRightGPD
68374947ADLeftGU9, XAN68412769ACLeftGPD
68374948ADRightGPH, XAN
68374949ADLeftGPH, XAN
68381706ACRightGU8, XAK, XAN
68381707ACLeftGU8, XAK, XAN
68381772ADRightGPG
68381773ADLeftGPG
68381774ADRightGP1
68381775ADLeftGP1
68382838ADRightGP2
68382839ADLeftGP2
Sales CodeDescription
GP1Trailer-tow, power/heated/puddle/turn/running/power-folding/black
GP2Trailer-tow, power/heated/puddle/turn/running/power-folding/chrome
GPGTrailer-tow, power/heated/puddle/turn/running/manual-folding/black
GPHTrailer-tow, power/heated/puddle/turn/running/memory/power-folding/power convex/trailer spotter light/black
GU8Trailer-tow, power/heated/puddle/turn/running/power-folding/power convex/trailer spotter light/black
GU9Trailer-tow, power/heated/puddle/turn/running/memory/power-folding/power convex/trailer spotter light/chrome
XAKSurround-View Camera System
XANBlind Spot Monitoring (BSM) with Rear Cross-Path Detection
GU3Black/power/heated/signal/puddle/running lights/trailer spotter
GPDBlack/manual
GPGBlack/power/heated/signal/puddle/running lights
GYFChrome/power/heated/signal/puddle/running light/power convex/trailer spotter
LFXPower adjustable convex auxiliary
Has anyone added power folding mirrors with the power convex option. my 22 3500 came with manual fold and I wanted the power convex as my 21 2500 had it. Is there a wiring harness or jumper to make the power convex button work?
Yes, you’ll need the switch- 52112478AA, and you’ll have to cut the hole for it in your armrest. You also need a jumper harness for it that I can build for you.
Yes please how much for your jumper harness. I ordered a whole new door panel.
