Dan222500
Also just got a ETA of 2/3 - 2/7.Mine was just built last week and was in D1 for 1 month.
D status!Brv10 can you see if there is an update on mine? I can't seem to get anything to come out right..
Sad.. guess the build date was just a way to buy them another month.D status!
The build dates have been wrong for most of this thread.Sad.. guess the build date was just a way to buy them another month.
Has to go back for the QC check, hopefully quickly.@OfficerDirtySanchez - build sheet populated this morning. Ramchat says it has shipped which we all know is not accurate. vin 3C63RRRL1NG196772
I had the dash camera and the radar detector set up on the windshield and used a fused power supply for the power. I could move the fuse from always on to off when I was not going to be in the truck that much to keep it from draining the batteries.Found my window sticker this morning. Everything I remember ordering is there, plus some features I didn't remember but am glad to have. I didn't see the box coating but no big deal if it's not there as I can easily get that done here. I'm beginning to wish I ordered the auxiliary switches, 'just in case'. I had them on my 2011 dually and never found a use for them. Now I'm thinking about bed lights, feeding power to a dash cam, non-RAM tpms power supply... Not a big deal. I'll probably be 6 months getting everything set up the way I want it.
I ordered this pkg and was not aware of the tire change. Are the included on/off-road tires still low(er) end firestones?I had the dash camera and the radar detector set up on the windshield and used a fused power supply for the power. I could move the fuse from always on to off when I was not going to be in the truck that much to keep it from draining the batteries.
If you can add the snow chief package to the truck I would suggest it. It's cheap ($805) and has the limited-slip dif, the aux switches, skid plate, on/off-road tires, and clearance lamps on the roof of the cab.
Did you look in the commercial settings in the EVIC?A couple of things I discovered were, there doesn’t seem to be a way to control the backup alarm. I couldn’t find anything in the settings for it so I may end up regretting that option.
Looks like they covered the narrow slots in the front next to the corners with the bed liner material. Look underneath the bed in the front and see if you can see the slots in the metal of the bed. They were about 2-3 inches long and about 1/8 to a 1/4 inch wide on my 2014 and 2016 model trucks.Not sure where to post this - but I will ask here and if there is a better place I am sure someone will tell me - or maybe just a quick answer.
Seem to be having drainage problems in bed with Rambox. Searched Bed Drain and Rambox Drain, but maybe I am unique? Parled on angle and previous truck had 2 drain slots in opposite front corners of bed - but I cant find similar drains on new truck - help - View attachment 30231what am I missing?
I don't have anything named commercial settings.Did you look in the commercial settings in the EVIC?
I have a chassis cab and mine is in the commercial settings
Not sure why they call it black interior because it's charcoal grey. I found that out today when I picked up my Limited.Just Ordered mine today, No Sunroof, now the wait begins, MSRP is $95160
Vehicle: 2022 3500 LIMITED CREW CAB 4X4 (149 IN WB 6 FT 4 IN Box) (D28M91)
Sales Code Description MSRP(USD) FWP(USD)
Model: D28M91 3500 LIMITED CREW CAB 4X4 (149 IN WB 6 FT 4 IN Box) 71,925 66,772
Package: 21M Customer Preferred Package 21M 0 0
ETM 6.7L I6 Cummins HO Turbo Diesel Eng 12,295 11,312
DF2 6-Spd Auto Aisin AS69RC HD Trans 0 0
Paint/Seat/Trim: PXJ Diamond Black Crystal P/C 100 92
APA Monotone Paint 0 0
*UL Limited Leather Bucket Seats 0 0
-X9 Black 0 0
Options: XF7 Dual Alternators Rated at 440 Amps 295 272
XB2 RamBox Delete -490 -451
SJE Adaptive Steering System 0 0
MDA Front License Plate Bracket 0 0
ADB Protection Group 0 0
AD2 Snow Chief Group 255 235
SEB Auto Level Rear Air Suspension 1,705 1,568
AHU 5th Wheel/Gooseneck Towing Prep Grp 545 501
ADE Cold Weather Group 145 133
ASH Night Edition 1,195 1,100
MDN Mopar Bed Step - Deployable 365 336
A69 Limited Level 1 Equipment Group 4,485 4,127
XH7 Tow-Mode Camera (Wired) 545 501
5N6 Easy Order 0 0
170 Zone 70-Phoenix Arizona 0 0
4EA Sold Vehicle 0 0
Discounts: YG4 5.5 Additional Gallons of Diesel 0 18
Destination Fees: 1,795 1,795
All factory tires are lower end from my experiences with new trucks.I ordered this pkg and was not aware of the tire change. Are the included on/off-road tires still low(er) end firestones?
EDIT; this pkg does not show unique tires
Do you have the auxiliary switches? If so, how do you set them for use?I don't have anything named commercial settings.
