They are rhe combo sports.
Automotive LED lighting for cars and trucks, including headlight, fog light, turn signal, backup, tail, interior, halos, demon eyes, boards, strips, and more!
www.diodedynamics.com
The one I used was actually a no name brand. I thought it was a curt, but when I went back through my Amazon orders it was this one. I bought it for my 2019 and sold that truck before I installed it.
Buy MITZONE 7-Foot 7-Pin Vehicle-Trailer Wiring Plug Harness Extension Compatible with Chevy/Dodge/Ford/GMC/Nissan/Toyota/Ram for Fifth-Wheel and gooseneck Trailers [Truck Bed Extension]: Wiring - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
To save some money you could get this one. Its way cheaper, but it will take lots more cutting and soldering than the other one since half of the wines are only a few inches long and have to be extended
I ended up also putting a 2 pin deutsch connector on the factory aux wiring pass through in the back of the truck so if I ever sell this truck I can move tbr parts over thr the next amd it will be plug and play. That long red wire in my pick is what goes to the aux switches, I cut it down to about 7" since I didn't realize the aux wiring was so close to the hitch. I wanted the lights to come on cia the reverse lights or via rhe zux switch.
This is what I used to tee the two lights into a single plug. That single 3 pin plug then goes to the 8pin connector from 7way harness. The 8th pin on the 7 way harness goes to the factory aux wiring which i also put a deutsch connector on.
You could save lots of money on deutsch connectors and just solder all thr wires together. I wanted the best possible seal on all the wiring and the ability to just unplug sections if I ever change or add lights.
