Oops ment 32*F brain fartl
good thing I keep my truck gauges set to Fahrenheit. I can wait until it gets a bit colder before messing with the cover. ;-)
My parts guy got the updated cover in and did a straight exchange for me. I put it on and presto it fits. Nice that they have shorter tabs on it now for the Limited grille. Only thing I wish it has was a couple of tabs by the camera cutout. I can see the cover on the front camera view. Thx for the part # Kobra!Turns out I didn't throw out the bag, and it has a part # on it!
Part # 68526832AA
And a couple of photos;
-picture from the manual showing the insert that gets unstitched and removed for the front camera
-photo installed on truck (sorry for distorted wide angle but up against the garage)
Hope that helps, but let me know if you need anything else!
B
Was thinking maybe a couple of small velcro strips on the grille might be just enough to hold it in.Glad to help, and glad it worked out for you!
It does seem like maybe there is a little fold right in the middle that might be showing up on your camera. I don't have any tabs on mine, but it seems to lay a bit flatter; at least from the pictures. I wonder if you can heat it a bit with a hair dryer and see if you can get it to lay flatter? (never had to do that, but it seems like the openings are similar)
hth
B
There was a TSB for this as a known issue (screw up) on Ram's part on the 19 and early 20 trucks.
Thanks @Brutal_HO I thought I had read about that TSB.
But, as to the rest of the drama about poor quality and hard to install?
My 3rd RAM HD in 7 years and each one came with a winter front; this one is the best one for overall design, quality and ease of installation -by far.
B
It's on page 2 of this thread.You guys wouldn't happen to know what the TSB # is by chance would you? I have tried searching for it, but haven't been able to find it.
I saw that, but that is not actually the TSB. It doesn't even come up in the NHTSA site when I search for it using the NHTSA ID #. Maybe I'm doing something wrong or looking in the wrong place to find it.It's on page 2 of this thread.
The cover is standard ?Standard on the Canadian diesel trucks. Never put mine on. I don't like cold. LOL
Should beThe cover is standard ?
I'll have to ask my dealer .... don't recall seeing it.Should be
Excellent. That's what I think too.It comes with the cold weather, or snow chief group option? Battery blankets and the like. Mine came with it, not sure exactly the package but it was under the back seat when I got my truck home. In my manual for the 2022 on page 139, it states the winter front cover should be used when ambient temps are below 32 F, 4 flaps open. If it gets below 0, 4 flaps closed. Honestly, it kept the truck temp warmer and that aids in MPG. I average 14.5 mpg around town in the winter so I feel it helps. It also gets your engine oil and trans temp up so they work more efficiently. They typically want to see oil temps between 190 and 210 on these long interval oil change engines. (I change mine once a year and never get to anywhere near 15k miles) Never had any issue over heating even when left on in 45 degree weather.
