if you have a 2019 or newer the procal will only set to 35, 45, 60, 65, 80 and 95. if you try lower than one of those it will automatically set to the next highest. ie if you try and set it at 20 it will go to 35 if try and set at 30 it will go to 35 . they trigger at 75% of those values so I have mine set at 35psi and they won't trigger unless I drop under 27psi.
