22RAMAlazan
could you post a pic from the front? id love to see how that wheel/tire combo looks w the factory offset. Truck looks great! Did you do the polish/ceramic yourself?-Chemical guys 5 year ceramic with polish
-Swing case on passenger installed (do not want to cover tow plugs on driver side)
-Toyo at3 35x12.50x20. No rubbing. Stock height.
-A pic of my ram and my brother in laws power wagon. He has 35x12.50 K02 on stock height for all those who are interested
Passive entry (completed only one side for now) and 15% tint on the front windows. Looks like some mudflaps/splashguards need to be my next mod!
The passenger side mirror is near useless when flipped in. I don't know if they're all like this but it seems to have a lot of magnification and I can't adjust it to where I need it.Free mod:
Flip in those goofy looking mirrors.
My mirrors are more useful in the tow position. Doesn't matter what people think. An additional benefit is if my mirror clears my dually fenders also clear.The passenger side mirror is near useless when flipped in. I don't know if they're all like this but it seems to have a lot of magnification and I can't adjust it to where I need it.
May i ask which bar and mounts you chose? I want to do the same but the RC is huge $$$20” light bar behind lower grille. Some were concerned the the grille would block the light.
My light bar is spilt flood on sides driving light center.
Got the bed step mounted last night. Now I need to figure out if I want to get one for infront of the wheels or not.
I got it from amazon, but its available form most truck acc retailers. Its made by amp research (part# 75324-01a). It is not listed as fitting the 2022's but a few members have installed it. I did not have to trim mine to fit. there was another guy on here that did (see this post).Where did you get the step?
All looks great, Bedrug will relax a bit over time…The Leer HF650M tonneau cover and Bedrug were happy to finally be broken out of their boxes. Wish I did better on the Bedrug install, but it turned out ok. Think I need to mess with the cover a little to make the back sit down a little lower though. The MD stickers, and probably 4x4, will come off tomorrow
that is the next purchase for my DRW. I love my rear bed-step, but defiantly want to add the side ones as well (on at least one side that is).Installed AMP Research BedStep2, part number 75417-01A, on both sides of the truck. After confirming with AMP that these do fit despite some reviews on Amazon claiming they do not, I went at it today. There was some customization needed to keep them from hitting the plastic trim at the bottom of the bed. I had to slot the holes inward from where their template has you drill. After that, the lever arm no longer touches the trim piece when deployed. The step does not touch the trim either when retracted. Be sure to align them in retracted position before tightening down the bolts. I had one noticeably crooked and had to go back and adjust after the fact. Not hard but just a little hassle.
Passenger side:
View attachment 28411 View attachment 28412 View attachment 28415View attachment 28416
Driver side:
View attachment 28417 View attachment 28418 View attachment 28419View attachment 28420
Slots after drilling 3/8" hole per template (this is driver's side, passenger is similar except no hoses in the way)
Thanks. First one I’ve installed myself. Last two trucks I’ve had the tonneau installer also do the bedrugAll looks great, Bedrug will relax a bit over time…
Wish they had something for the front so I can check the engine and trans dipsticks. I can just barely shut the hood! lolthat is the next purchase for my DRW. I love my rear bed-step, but defiantly want to add the side ones as well (on at least one side that is).
