True "dat. I just called the dealer and the guy says " paper work shows they charged us for the slider and the keyless entry"..... How about you go and look.. UGH.Don’t assume anything in 2021, sir
ARE built mine without a slider.
2019+ same bed, maybe even the same as gen 4Has anyone with a 2022 longbed purchased a softtopper? The website only has the 8' option available for up to the 2020 model year. Did you purchase this softopper, and how is the fit? The bed dimensions look to be identical for the past couple years, but figured I'd ask the community for confirmation.
Did it get installed ?Finally. After 16 weeks I get my Z series installed tomorrow! 2021 Ram 2500 6.4L Hemi. Crystal Granite color. I sprung for the Cap, Keyless entry and the front Drop down slider. It also comes with fully carpeted interior, Frameless back glass and screened side windows -ETC Hoping fit and finish are good!
Yes, sorry, just logged in and found this notification. Everything was very good except the carpet in the upper right hand corner of the cap as you look in from the tailgate. I thought at first there was just a big tear or something up there but as it turns out it is the factory "cut" where they made the corner. It must have not glued down all of the way and lifted up some. Still appears to be a little short on carpet but I will just lay it back down with some glue after the cold weather breaks. I don't want to go through the BS of going back to the dealer and having them take it off or whatever they are gonna BS me with.. Not worth it in my opinion and honestly after I fix it you wont ever see it or know it was there. Everything I ordered came in and was perfect. No blems in paint or shell and no other issues.Did it get installed ?
I have only had 2 caps in my life. The first one was 2nd hand and was a leer with a framed door. I actually feel like the one piece glass, frameless door feels more secure or solid. It could be that the leer was 2nd hand and worn down but it actually twisted more than this A.R.E. As far as view is concerned I can still see out of my back window fine when looking for vehicles. If anything it "bubbled" the standard no cap view a little bit. Honestly I just use all of the cameras when I am backing up so maybe I don't notice it as much as another person would.Another question for those with frameless rear doors: do they feel as durable or secure as the framed ones? And in general for all caps, do you feel they cut the view from the rearview mirror down a whole lot, or can you still see a little bit back there?
My 2 cents... Anyone can reply with the part numbers of their struts etc. I dont know how much it will help you because they seem really sensitive to different weights. What works for me might be too light or too heavy for your application.. I will look on my A.R.E and see what they are but have you contacted the MFG of your cap? Probably a dumb question..Those of you with cab height toppers with frameless rear doors, can you tell me what you have for shocks/struts/springs/supports for the rear door? Mine are not supporting the door, I ordered exact model replacements to what was installed thinking they were bad, but still not supporting.
I have an ARE V series (framed door), yes you loose a bit of visibility (darker due to the extra layer of tint, plus obstructed view where the pillars are) HOWEVER the rear view mirror is still absolutely functional and useable to see what is behind you. Not much different Rear view than an SUV.And in general for all caps, do you feel they cut the view from the rearview mirror down a whole lot, or can you still see a little bit back there?
I have contacted the mfg, waiting on a response. What I am looking to gain from this is the capacity of the shocks/struts/springs. The ones I removed and replaced are 43lbs/ strut, which evidently is not enough. I could probably do the calculations to figure it out, but would need to figure out the weight of the door.My 2 cents... Anyone can reply with the part numbers of their struts etc. I dont know how much it will help you because they seem really sensitive to different weights. What works for me might be too light or too heavy for your application.. I will look on my A.R.E and see what they are but have you contacted the MFG of your cap? Probably a dumb question..
This is my first frameless rear door. I think it feels more solid, but as far as durability, I see more caps with frameless rear doors with missing doors than framed. My dad has had caps on the last 4 trucks he has owned, the last cap had a frameless door and ended up shattering when he attempted to open it (froze shut). It was cheaper to replace the entire cap than to replace just the door. I love the look of frameless, but am careful with it.Another question for those with frameless rear doors: do they feel as durable or secure as the framed ones? And in general for all caps, do you feel they cut the view from the rearview mirror down a whole lot, or can you still see a little bit back there?
Part of the reason I went with the V-series(framed rear window), is that replacement glass would theoretically be cheaper and easier to source.This is my first frameless rear door. I think it feels more solid, but as far as durability, I see more caps with frameless rear doors with missing doors than framed. My dad has had caps on the last 4 trucks he has owned, the last cap had a frameless door and ended up shattering when he attempted to open it (froze shut). It was cheaper to replace the entire cap than to replace just the door. I love the look of frameless, but am careful with it.
I used the numbers off the ones originally on the cap when I bought it used, new still cannot hold the door up, temperature doesn't matter. I am a 45min drive from any cap dealer/installer, so swinging by is not an option, waiting on manufacturer response. A buddy has the exact same cap, but the part number on his struts does not seem to exist, sent request to the strut manufacturer. The rear windows on these things are very similar if same cap style (cab height).I’d look at the numbers / info on the factory topper gas struts and order a new set. If that didn’t work i would swing by my installing dealer and get them to order me a set. I wouldn’t try to guess weights and lengths.
Too much power on the struts can also damage the hinges if they’re also a hair too longI'm with @Rockcrawlerdude on this if only for the reason that I wouldn't want to risk having too strong of struts that may result in having to close the glass too hard or too much pressure causing the rear to shatter, potentially while driving.
