Steering directed lights
joesetum
Hey everyone, was trying to see if anyone else has had issues with the steering directed lights on the Limited trim trucks? Mine were working fine, I put on some thuren suspension components, wheels and tires, then took the truck to Les Schwab for an alignment/peace of mind. The lights were working normally with the steering wheel turns prior to me taking it into them, was wondering if anyone has had issues with this after taking their trucks in for alignments or what not. Was wondering if they unplugged a harness or screwed something up when they adjusted the drag link?? Thanks for any help anyone can provide
Do they come on with turn signals?
Are they still enabled in the Uconnect settings?
The corresponding side fog lights are activated with turning the wheel and turn signals, but the actual head light isn’t turning with the wheel anymore. Yeah I thought that could be an issue and checked, they’re turned on in Uconnect. I tried toggling it on and off and restarting the truck but no luck
Mine activate anytime, turning with or without using turn signals.
Do your fogs work okay? Just not coming on when turning, or not working at all?
If nor working at all, I suspect a plug undone. If not working only when turning, I suspect a software problem.
Just a thought - do the turning fogs come on anytime headlights are on or only if they are set to automatic? I would go out and verify that, but I'm on Maui drinking Mai Tais :cool:
There is no issues or changes with my fog lights activating or working. Only with the actual low beam head lights not turning in conjunction with the wheel as they did before taking the truck in. Being on Maui sounds a lot better being stuck at work haha
If I'm reading you right, you are mistaken about the low beams turning with the wheel. The low beam headlights do not turn with the wheel. When you turn the wheel the fogs come on and light up the area you are turning into.
Yes, while on Maui I have nothing to concern me other than relax and enjoy. It's been my goto place for years.
The headlights on the Limited trim (led projector) are dynamic and the projector should turn slightly when turning.
Wow, didn't know that. Makes my 2020 Laramie is nearly obsolete using only the fogs.
Yeah they do slightly move, only like 30 degrees or so on steering wheel movement. That’s the only reason I included the trim level in the original post
Do the fogs on the Limiteds move? I just picked one up a couple of months ago and already have the Baja Designs Squadron Fog kit on order. Curious if I just screwed myself out of a cool feature I paid for.....
They don't move... but if they are off, once you slow down enough, they light into the corner you are turning
At speeds under 25mph, the fogs will come on with enough steering angle AND/OR the turn signal.
