I do tow, but no max tow and no 5'er. Most would be a 12000lb lobster boat that I tow 2x a year, other than that, just a dump trailer. Side note - I currently move that boat with my max tow package half ton = Sketch!Do you tow at all? If so I'd nix the 37's just for that reason.
To me 37's look too big on just a leveled truck, not a fan of that "stuffed" look but that's me. I prefer leveled and 35's or a ~3-4" lift and 37's, I think those combos look the best but again, that's just my opinion.
This is power wagon stock height?35x12.5 x 18 with a +18 offset
Do you have any issues running 17" wheels?My opinion: A Cummins with a lift or level go 37s. No lift or level go 35s.
Heck, sometimes I even think my 37s look small on my lifted truck after having them on there for a while now.
This is no lift with 37s. For me, this is too stuffed.
3.25" Carli added
Cool. I haven't decided on a set of wheels yet.I don't have any issues. Discount tire knew where to place the weights to miss the brake caliphers. I have heard some wheels have more of an issue. I took the easy way out and went with a 17" I knew friends had no problems with.
It's good to see other people have red trucks I was feeling alone for a bit. Lol
Offset depends on the width of the wheel and tire. A 9" wide wheel with -18 mm is going to stick out quite a ways. The pic below is +20mm and the tread is just covered on a 12.50 wide tire. The sidewall does stick out a bit. Those are with the stock Laramie flares. A 9" wheel with -19mm offset will stick out a little over 1.5" farther. So I guess it depends on what you are looking for. It will definitely keep the truck dirty. LOLWould -19mm offset stick out too far without flares?
The plan is below:Offset depends on the width of the wheel and tire. A 9" wide wheel with -18 mm is going to stick out quite a ways. The pic below is +20mm and the tread is just covered on a 12.50 wide tire. The sidewall does stick out a bit. Those are with the stock Laramie flares. A 9" wheel with -19mm offset will stick out a little over 1.5" farther. So I guess it depends on what you are looking for. It will definitely keep the truck dirty. LOL
The plan is below:
315/70/17 Ridge Grapplers Load Range E
17x9 Raceline Wheels 8x6.5 w/ -19mm backspacing
That’s a terrible plan. The offset is wrong. Scrap that plan. Try again.The plan is below:
This ^I went with +18mm Method NVs and 35”x12.5 on stock suspension. Slight little rub on plastic in uneven terrain but a heat gun will take care of that
Now that you are makin me blush here is a side profile too. Doesn’t fill as well as a 37 but not small by any means.This ^
Do this ^
The plan is below:
...... Doesn’t fill as well as a 37 but not small by any means.
