Rectangle LED Fog Lamp onto 2020 Tradesman
Scott534
Hi,
I'm hoping someone can help me with this install. I have a 2020 Tradesman 2500 that did not come with fog lights/lamps. It has the cover over the hole. I obtained stock rectangle LED fog lights from a 2020 Ram 2500 and would like to install them in the stock location on the bumper. Has anyone done this mod? I've seen the other threads with the smaller fog lights and bezels, but couldn't find anything with this style of fog light.
Thanks!
Scott
it's just the bezel thats different. otherwise it's the same type of idea on installing them. the fog light thread should cover all of that.
Thanks for the help. Any idea where I can find the bezel for these fog lights? I have researched all over the web and can't find anything.
Also, is the mounting bracket the same for these as it is for the other fog lights?
brackets are the same. part #'s are in that thread. lemme find it and I'll tag ya if someone doesn't throw em up here first.
Awesome, thanks for the help.
Is this the bracket you used? Bracket - Fog lamp 68449383AA
I’ll go take a look and let you know. I bought a bumper that had them in there and only needed to order the bezels.
Did you ever get the part number for the bezel and bracket? Looking to swap my Halogen Fogs to LED.
I installed the bracket and rectangular lights on my 21 tradesmen but I have yet to find the bezel.
And the foglights, bezels, brackets are all the same between 1500/2500/3500/4500/5500
That’s a 1500 bezel
I didn’t think the led headlights/foglights were available without front parking sensors
You are correct, my bad.
The correct part number for 2500/3500 LED bezels with park sense is Mopar 68449338AA.
The 68449321AA mentioned above must be (just guessing) the same without the park sense holes.
No the 1500 bezels are different…different shape, you can see the inboard lower corner is cropped on the 1500 so the parking sensor is located next to the light rather than below, while the HD upper inboard corner is slightly cropped.
HD:
1500:
I am uncertain about the actual light, they may share that part, though the cutout looks a bit different so maybe not.
Edit:
Here’s the CJC/BD Fog kits (round bezel) on a 1500 vs a 2500, good visual comparison of the two bezels
Interesting. I’ve only seen LEDs with the front park sensors before. I can’t figure out how to configure it like this either online…how is your truck configured?
Tradesman. Added LED headlights and foglights in my driveway.
