2022 3500 cummins 4x4 level kit?
newtoy
Looking to order a new 2022 Ram 3500 with factory rear auto level suspension is that going to be a problem to put a level kit on this truck ? Not sure I need the option just asking before I pull the trigger on the new truck order with that option.
It depends on the level system you go with. Carli makes 3.25" lift for the auto level system but no pure level kit for those trucks.
So what I’m doing after talking to the guys at CJC off-road is I have to put 1” spacers for the axle and airbags. I ordered a Drw Laramie with air, decided I didn’t want air and told dealer to cancel the air, got a reply a couple days later saying rear air is cancelled. Ordered the 2.5” leveling kit and it’s sitting in my garage. Got my build sheet a couple weeks ago and the air did not get taken off so now my truck will have. But like I said CJC just said to add 1” spacers and all should be fine. If it sits to low in the rear I can do 1.5” or 2” blocks to make level.
Still waiting on my truck! It’s been sitting in Portland rail yard for a couple weeks now, tomorrow is the last day of there estimated delivery day to the dealer. Hopefully it shows up. I have an appointment Wednesday for ppf and hoping to get everything else installed Friday. If. Big if the truck gets here Monday or Tuesday.
Found this link while trying to decide on paying the dealer $150 to re calibrate my speedometer should I decide to purchase a larger tire for my 2022 RAM 2500 Big Horn. I'm not looking to add a Lift Kit so only looking at tires that will fit without rubbing. Just want to fill the tire well for a better look. Original tire 275/70/18 going to a 295/70/18 Speedometer only changes 2 mph. Speedometer will show 60 mph but actual speed will be 62 mph. I don't think it's worth paying the dealer to calibrate the speedometer given most Law Enforcement allow 5 miles over the posted speed because of Radar Calibrations. Hope this helps other members
Did you install the kit yet?
I’m the opposite. Got my truck Tuesday but waiting on my kit to show up. Not sure which way would be more torture.
Did you get a dually? If so what wheels/tires did you go with. I ordered my leveling kit a couple months ago so I’ve had it for awhile now. Also got a Thuren adjustable track bar.
