ACEd
In response to diameter question, here are OE Tire specs and the available Cooper Discoverer AT3XLT specs for comparison. As you might notiice there is some minor variation in OD for same size - this is not unusual. It is also worth noting these are at full tread depth. (note tread depth in 32nds of an inch) The dimensions below are typical for highway and moderate AT tires. MT and Extreme Off Road Tires may have slightly deeper tread and possibly slightly larger diameters when new. If you have a specific tire in question, generally you can go to Manufacturer's website and fine data for a specific tire.I believe a 295-70 is a 35” tire. I don’t remember where, but i watched a Utube where it was proved a 35” tall will fit on a stock suspension.
| Load Range | Sidewall | Allow Rim Widths, in | Meas Rim Width, in | Section Width, in | Overall Diameter, in | Tire (Tread?) Width | Tire Weight, Lb | Max Load Rating, Lb | Tread Depth, 32nds | ||
| OE Firestone Transforce HT | |||||||||||
| LT275/70 R18 | 125/122S | E | Black | 7-8.5 | 8 | 11.0 | 33.10 | 8.6 | 49 | 3640 | 15.0 |
| OE Firestone Transforce AT | |||||||||||
| LT285/60R20 | 125/122R | E | OWL | 8-10 | 9 | 11.5 | 33.40 | 9.0 | 56 | 3640 | 16.0 |
| Cooper Discoverer AT3/XLT Size | |||||||||||
| LT285/75R18 | 129\126S | E | BLK | 7.5-9.5 | 8 | 11.5 | 34.84 | 8.9 | 60 | 4080 | 17 |
| LT265/70R18 | 124\121S | E | RWL | 7-9 | 8 | 10.7 | 32.64 | 8.62 | 53 | 3525 | 16.5 |
| LT275/70R18 | 125\122S | E | RWL | 7-8.5 | 8 | 11.1 | 33.23 | 8.9 | 57 | 3640 | 16 |
| LT295/70R18 | 129\126S | E | BLK | 7.5-10 | 8.5 | 12 | 34.25 | 9.41 | 61 | 4080 | 17 |
| LT285/65R18 | 125\122S | E | RWL | 8-10 | 8.5 | 11.6 | 32.56 | 9.41 | 57 | 3640 | 16 |
| LT305/65R18 | 124\121S | E | BLK | 8.5-11 | 9 | 12.2 | 33.58 | 10 | 62 | 3525 | 16.5 |
| LT325/65R18 | 127\124R | E | RWL | 9-12 | 9.5 | 13 | 34.61 | 10.59 | 68 | 3860 | 16.5 |
| LT325/60R18 | 124\121R | E | BLK | 9-12 | 9.5 | 13 | 33.35 | 10.63 | 63 | 3525 | 16.5 |
| 35X12.50R18LT | 123R | E | BLK | 8.5-11 | 10 | 12.5 | 34.96 | 9.88 | 66 | 3415 | 16.5 |
| LT285/60R20 | 125\122S | E | BLK | 8-10 | 8.5 | 11.3 | 33.7 | 9.69 | 60 | 3640 | 16 |
