NO LONGER AVAILABLE: Looking for a Part Number? Must provide VIN (only up to model year 2020 at this time)
Status
Not open for further replies.
Thank you so much! Really cool of you to offer this, and your time in looking all of these up.
@01Time, I have a request:
3C6UR5DJXLG249436
3C6UR5FJ6LG146544
3C6UR5SJ4LG248463
Looking for Instrument Panel Cluster- Mask and Lens for these 3 VINs. Thanks
I would like to see if you can help me locate the part numbers for the pins that would be used for the bed extender with the Rambox divider. I had seen it mentioned previously in another thread but can no longer find that thread or the part numbers for them. I am attaching a pic of the bed where the pins would be located along with where they go in the cargo divider. Here is my vin 3C6UR5SL1NG105071, thank you for your time!!
These are the parts listed for my 1500. I am not sure if they are the same for the 2500. At least it is a starting point...
Pivot Joint Grommet - Mopar (68054997AB) #13 in diagram
Swivel Release Handle - Mopar (68054996AA) #12 in diagram
3C6UR5DJXLG249436
3C6UR5FJ6LG146544
3C6UR5SJ4LG248463
See attached.
I don't have any 2022 info, but attached are the parts for a 2021 2500 if it's helpful.
Thank you Ickabod & 01Time for the help and references, got the pins ordered!
The grille letters should fit any grille. The only two part numbers listed for grille letters are 68358569AA (chrome) and 68358570AA (black). When I added surround view I took the letters and nostrils off my non-camera grill and installed them onto the grille with the camera. Did you get a backing plate for the new grille? Grille 68443251AA requires backing plate 68459117AA.
If you can get me a VIN of a night edition HD w/o surround view I can tell you what grille came with the truck.
Attached are a full list of the parts for the grilles.
I just noticed your response thank you so much 01Time!!! You are too kind.
Happy Thanksgiving!
@Lary0071 post here someone can help
I am giving up. I've sifted through AllMoparParts looking for the missing upper 1/3 panel and I'm not seeing anything. I tried backing to a 2021 thinking that this would help turn it up, but I'm empty handed.
If anyone can throw me a bone in a part number for my 2022 Longhorn Dually, I'm wanting a part number for the rear wheel well upper plastic panel that is missing from the factory.
I have the front 1/3 and the rear 1/3 plastic, but if you stick your head in and look up you see my painted steel truck bed is exposed in the upper 1/3 and you'll see that all rocks, water, salt and debris will pummel that need into a chipped and rusted mess in short order.
I need that covered!
2022 Patriot Blue 3500 Dually Limited Longhorn 8' bed.
2022 Patriot Blue 3500 Dually Limited Longhorn 6.7L with 4.11 gears.
Unfortunately the program I have doesn't have any 2022 info and is limited on 2021 data. But here's the 2020 parts list that might be what you're looking for. If I'm way off let me know and I can try looking for something else.
VIN NG121898. Looking for the part circles in red. Thank you very much and Happy Holidays!
Could you email me that? For some reason I can not download it.
Missing a the few digits for the VIN to be sure what truck I should be searching and filtering (the EPC requires all 17 digits), but it looks like it would be somewhere in one of these attached lists.
No prob. Here you go…
3C63R3PL0NG121898
Thank you! Appreciate it!
It’s probably the exact same
Part in 2020 and 2021. Could you check please?
Here’s a 2020 vin with the equivalent limited black interior- 3C6UR5SL2LG198633
I wish I could help you out more...but here (attached) are all of the listed trim pieces for the VIN that Jimmy07 provided.
The part doesn't appear to be pictured in the diagrams. I even pulled this part off my truck to look for a P/N, but it had all sorts of numbers that were not part numbers.
I'm trying to upgrade my MY22 Laramie, to have a few options that I didn't have the capability of adding.
Currently I'm working on adding Blind spot and Surround view.
I have placed an order for the tail lights.
I know the Mirrors need the camera for the surround view, it was posted that the Right mirror is (6836 1478 AC) which parts sites are showing as correct for a MY22.
However the left side posted (6836 1479 AC) is showing that it doesn't fit a MY22. Can I get a confirmation or am I loosing my mind.
If it helps here is a sample VIN and my VIN
MY20: 3C6UR5KL3LG286817
MY22: 3C6UR5FL3NG167565
Status
