That is a sharp looking capHere it is. ARE Z Series cap. 2021 Ram 2500.
That is beautiful!! Do you mind me asking how much you paid for that?Here it is. ARE Z Series cap. 2021 Ram 2500.
I ended up putting mine up a bit higher...Light is your friend
my hatch on my topper has a rubber seal around it.What does everyone's cap/topper have for a tailgate seal? By this I mean is there an additional rubber seal on the door in the area of the molded tailgate cover? We had some rain last week and I got a lot of water coming in the bad from the tailgate area and I noticed a t-channel where a seal could be installed, but don't have any reference if one is supposed to be there or not, or what it would look like.
you can also get a cargo net and use it to store light stuff up off the floor. I used it for coats and what not...Strung up a clothes line in my topper. Some 1/4-20 eyelets , Some paracord, couple of taut-line hitches. Thanks @el_barto (i think) for sharing the idea earlier in this thread View attachment 25704View attachment 25705
This is a pic of the area I am talking about. You can see the t-channel. I thought I had seen an additional sweep seal on some others in this area.What does everyone's cap/topper have for a tailgate seal? By this I mean is there an additional rubber seal on the door in the area of the molded tailgate cover? We had some rain last week and I got a lot of water coming in the bad from the tailgate area and I noticed a t-channel where a seal could be installed, but don't have any reference if one is supposed to be there or not, or what it would look like.
The bottom of the hatch has a molded cap that fits over the top of the tailgate.
If water gets in, on mine, it probably came in the bottom corners of the hatch and/or between the tail lights and tailgate.
Can someone with a midrise cap do me a favor? I'm curious what the interior height is, and the opening height is. If you could throw a tape measure up from the "upper" bars across the floor of the bed to the lowest part of the roof in the cap, and do roughly the same with the opening, and just let me know what model cap you have so I can have a rough idea.
I'm trying to see how much height I'm gonna have inside if I put a cap back on, and if I can do a decked/truck vault/DIY and also comfortably sleep inside and if I can put a dog kennel in the back. Appreciate any help here.
you should have blunt wires for that under your spare. I did.For any cap in general installed on one of these Rams, how does the installer wire them (for brake light, overhead light, or even power locks)? Do they have to cut into existing wiring or do they use some sort of connector?
