AnthonyD1978
I'm surprised to see the rear shocks aren't the same additional length as the coils. The Carli coils look like they are 2-3" longer, but the shock only looks 1.5" longer. Perhaps it's the angle.
I'm interested in seeing how you like the kit vs the factory. I went with Thuren for my setup but the rear coil is so soft that any weight really pushes it down. Thinking about a few different options but curious how you like the rear coils.
The shock is what limits the travel. From what I've seen so far doing this install, 2 things limit them from going with a longer shock.
On the Power Wagon the driveshaft actually makes contact with the skid plate at full droop. Carli fixes this by providing a spacer to lower your skid plate so it doesn't make contact. Once that's fixed and you want even more travel you will quickly come to the limit of your brake lines having enough slack in them to allow the rear axle to drop any more (unless you want your brake lines to be ripped out).
Since I'm in a Power Wagon the rear coils are stiffer with more payload (about an additional 500lb if I remember right). So on a power wagon they are an increase. On other trucks they would be softer. Not sure by how much though. I believe Carli lists the ratings on their site.
