ProClip USA No-drill phone mount
Hstone556
Installed the Proclip 19+ mount with phone cradle. Ran the wire into the dash and down to the port in the center console. Solid mount and now full time Apple CarPlay.
Correct, just clips on and has a very small strip of two sided tape on the vent side. It’s solid, no movement at all. Only thing I wish was different is the angle was more towards the driver.
You can always go with ProClips tray mount that uses the factory screw holes in the dash try. That way you don’t have to worry about removing that nasty double sided tape and you can turn it anyway you’d like. Once you mount it, position it and tighten everything up it won’t budge. The best mount that I have ever found and used.
Not sure why you would need a phone mount? Once the phone it plugged in, I don't look at it again and can access what I need through AA.
I have the same mount and will agree with the quality and ease of install. Excellent product.
I have a mount to try and be a little more hands free. With a base tradesman I don't have the fancy screens and navigation and so on. With the phone on the mount and able to rotate 90 degrees, it works well for that purpose.
It’s not just a means to make Audio calls for me, I use it to FaceTime my GF and my daughter sometimes and having a solid mount makes the most sense to me.
I’ll be using that mount as well, to use as a dock for my Garmin InReach Explorer+. It was most useful traveling through zones with no service. The cradle in my Tacoma was ideal, I’m happy someone makes solid products for the Ram as well.
the only thing is now missing is
a bluetooth carplay ...
I got one of those CarPlay things from China. Works perfect. However it does like an install and thought for sec it was gonna download a virus or something...I was sure to give them a positive rating when the auto-email for rating was requested LOL
I have the ProClip in my truck as well, but not with the integrated connector.
Very happy with it; it’s absolutely rock solid, even offroad. Only negative is that it does block the airflow from that vent a bit
That's a great mount, probably the best. However, they don't have one for a truck with the 12" screen.
Ram mount bases. I used one that had to be cut down a bit and holes drilled to match the dash cubby. Longer screws and Bob's yer uncle.
Top level page for B size mounts and parts
Proclip has a pedestal mount now for 12" screen trucks, but I prefer the RAM mount system (also had lots of it.)
X2 on the ram brand mounts. I have one in my crawler, phone didn’t budge when I rolled three times. Cheaper mounts have snapped right off on just large bumps
