Need anything from Tech Authority?
Possum
I've got some time left on my subscription.
can you grab the wiring schematic for the bed led lights? I want to see if my tradesman has the harness and want to know where to look!
Here you go elephantrider
  • LAMP-CARGO BED-LEFT.pdf
  • LAMP-CARGO BED-RIGHT.pdf
  • SWITCH-LAMP-CARGO BED.pdf
Possum
Can you get the schematics for power running boards?
Have the board part numbers. Looking for the hardware kit and install procedure. Thanks in advance.
Trent
Possum
Trent
  • 2019-12-30 09_39_27-https___wiring.dcctools.com_svg-viewer_svg_view_metadata_location.htm_type...png
  • 2019-12-30 09_39_30-https___wiring.dcctools.com_svg-viewer_svg_view_metadata_location.htm_type...png
  • 2019-12-30 09_39_34-https___wiring.dcctools.com_svg-viewer_svg_view_metadata_location.htm_type...png
  • 2019-12-30 09_39_11-https___wiring.dcctools.com_svg-viewer_svg_view_metadata_location.htm_type...png
  • MODULE-POWER SIDE STEPS C1.pdf
  • MODULE-POWER SIDE STEPS C2.pdf
  • MOTOR-POWER SIDE STEP-LEFT.pdf
  • POWER-SIDE-STEP-SYSTEM.pdf
  • MOTOR-POWER SIDE STEP-RIGHT.pdf
Subscription is over, but if anyone needs anything let me know. I downloaded most of it.
I have a tradesman noticed under the rear seat theres a plug on each side thats just fasten to the seat bracket frame. Any clue what theyre for?
Possum, in your travels within the Tech Authority documents, did ya run across any specs for sheet metal alignment? More specifically, +/- tolerances relative to the lateral alignment of the box with the cab. Ram's Body Builder documents don't go into that kind of detail and the question has been asked here.
Many thanks!
Many thanks!
I did see a document that talked about body tolerances but I didn't save it
For the rear heated seat option maybe? Or it could be for the rear seat courtesy lights??
I'm on my phone so the SVG file is blurry, but is this where the plug is? If so it's part of the interior courtesy lights.
Im trying to add Auxiliary Switches to my 2019 Ram 3500. The switch connector behind the center stack has the wires there to work the switches. These wires run down to the first black 59 pin connector under the dash by the kick panel. This is connector "XY125A" I'm trying to find out what I need from that connector on the male side to be able to pass through the firewall and connect to the Auxiliary Power box under the hood. Can you help me out?
I’m trying to find the lock actuation wired for the tailgate. Any chance you have some diagrams for that?
I’d be curious what’s needed to get lane keep assist working on my Ram Laramie 5500.
