Auto start steering wheel and seat heat
GVBob
Can the cold start cabin temperature threshold be raised to cause the seat and steering wheel heater functions to turn on? It seems like about 40 degrees it works but not much warmer than that.
I was just going to post on this. I cant get mine to auto turn on even though i have it set to do so for all starts. AZ doesn’t usually get that cold.
I'm pretty sure it has to be cold enough to activate, might not be cold enough in AZ. Its definitely cold enough here in Northern CA, but on some warmer days (still not warm enough) it doesn't work. Would like to raise the threshold.
There is nothing I've read/seen in the manual which states this temp is adjustable.
Thanks for the reply. I wonder if the actual service manual would have the info. I'm planning on stopping by the stealership and asking a tech. If I learn something I'll post it.
