Bombdigitty
Anyone with the OEM fifth wheel prep puck system experience side to side play between the pucks and whatever you have installed.
I ordered the Husky adaptor bracket to use with my Husky fifth wheel hitch. The feet on it that lock into the pucks are a bit smaller than the opening in the puck system.
It allows for almost 1/2 inch of side to side movement. It is quite noticeable and unsettling when taking sweeping corners at highway speeds.
Pictures attached are of same corner of puck system with adaptor locked into place. Slid all the way to one side, then the other.
If you look at the locking handle, it slides from approximately 5-3/8" to 5-3/4"
