Razzman
I agree. The SM is really great here, he said I won't let it go any less than perfect. It's not like I really have to have it right now anyway, I just miss it lol.
I could not agree more. the AC blows cold after the TSB was performed but the fan speed is still slooow!!! very frustrating.Wow, thanks for the Pic. For sure the TSB helped. My only wish at this point is for more blower/fan speed. Need more airflow.
I never really had an issue with the fan speed that I recall, maybe because I was used to the fan speed in my previous '17 1500 Laramie which was about the same. My biggest issues before the total failure were temperature imbalance side to side, not that cool and blowing hot at times when on A/C. After seeing the truck the other day and talking with the mechanic and SM I understand why this happened and why the total replacement is necessary.Wow, thanks for the Pic. For sure the TSB helped. My only wish at this point is for more blower/fan speed. Need more airflow.
As had I until mine totally failed, I had no choice. As I was told any of these affected trucks can have total failure due to the problem.yikes I have been thinking of taking mine if for the tsb but this has me thinking maybe just live with the crappy ac.
Pretty much where mine was before the total A/C failure. Get 'er done!I've been wanting to do this for a while, but I think the past 2 weeks have pushed me over the edge. The AC won't kick on cold at all unless I turn it all the way to low, and then I have to wait minutes for it to get even cool, not cold. It's to the point where it works so poorly that the vented seats don't even do anything.
No nut on mineSo turns out whoever performed the TSB didn’t reassemble the steering column in my truck correctly. Could have easily killed my wife and kids today, thankfully it only came apart at the inside of the firewall when she was pulling into my driveway.
This is how I found it when I looked to find out why the steering wheel was turning completely freely.
I assume there is a nut that’s supposed to be on the other side of that bolt? I couldn’t find that nut anywhere, I assume somebody forgot to put it back on after taking apart the dash.
The clock spring is broken now because the wheel got turned too far. Air bag lights and stability control lights are on.
You can imagine my mood.
Please check your steering column after the TSB so this doesn’t happen to you.
If this happened on the highway there could have been less breathers on the road?What does this have to do with the breathers?
