rfullen280
Say a guy has some possibly bad DEF. How do you drain that tank (without removing it)? Is there a setting to "run" the DEF Pump? Maybe in ALFA?
After pulling the pump I took a garden hose and sprayed the inside of the tank, I let it dry and wiped it out all out real good (once the pump is out this is easy through the 6" hole) I also unhooked the DEF injection line, flushed and blew it dry as well.That is an excellent idea I got 10 feet of 3/8 hose and I disconnected the fittings at each junction and fish the hose all the way out to the Phil port sucked out what was left in there which is about a gallon and then pumped a gallon of freshwater back in and now I've been driving around to slash that up a bit and then I'll go back to the house and try to suck out that gallon of water and then I will do what you suggested. That seems like the best way to put it in storage
Yes, the truck still regens just uses no DEFso the tune you're running still allows for regens, with no def action?
