Ordered 6/14, Ram 5500 Chassis cab. My dealer said I’m in JS status. Can you guys enlighten me on what JS is?
Build codes.
Unscheduled:
BA – order entered in system by dealer
BB – fleet order only – review by bid department
BD – special equipment processing
BE – edit error – coding error which must be corrected before order can be scheduled
BG – order has passes edit but cannot be scheduled regardless of sold status
BX – good order available for scheduling
Reason Codes:
F – Finance hold – automatic cancellation after 15 days
B – Model or option build out. Your order exists but isn't fully confirmed yet. Plant doesn't know about it yet. Systems are checking the order to ensure it's valid in terms of sales codes.
L – Material restriction
M – Material hold (fleet)
ZA – canceled order
Scheduled:
C – Tentative schedule. Your order is "subfirm". The plant can see the order at this point but it's not fully committed to building as the supplier may or may not be able to get parts to the plant to build the vehicle.
D – Firm schedule: serial number assigned. Firm order. Your order now has a name instead of a number:
D1 – Gate line: unit sequenced for production, est. ship date assigned.
The date is set for your truck to be built. The plant knows when it should have parts sequenced for building and it should start to be built within 48 hours of the date set.
D2 - It's going to be built. The computers are being programmed, materials are being sequenced, framing is about to occur.
Build:
E – Framing. Metal is welded together to form the body and frame. The body is inspected at the end of this step to ensure it's within tolerances.
F – Paint. The metal is coated, primed, sprayed, clearcoated, polished, inspected, and hand finished if necessary.
G – Trim. The engine is installed in the chassis, the interior is installed, the chassis is mated to the body, the bed is put on. At the end of this, your new vehicle is built.
Built:
I – unit built, pending final inspection. Your vehicle goes through a battery of shakedown tests and measurements are taken to ensure the vehicle looks and performs as expected.
J – Vehicle passed final inspection but not released to carrier
Get your Build Sheet here: https://fcacommunity.force.com/RAM/s/equipment-listing
(Build sheet input is CASE SENSITIVE)
JB – shipped to body vendor. JB/KZP-The vehicle is sent off site to have a spray liner put in, steps, etc.
JE – shipped to emissions
JJ – consigned to body vendor
JS – shipped to storage
KZ – released by plant and invoiced. The truck is ready to be shipped. The dealer is actually charged for the truck. As you all know, this can be a source of delay. Typically you see two statuses here: Awaiting Shipment and "Staged for Shipment".
Nice truck. He said level C and he pulled the mirror out manually. Not power folding mirrors.
Spoke with my dealers GM today regarding BH power folding mirrors. He relayed to me if the order build sheet shows level 1 or B, the truck will be equipped with power folding mirrors. If the truck was ordered later, and is A or C, it will not have power folding unless the truck has the trailer tech package. Guess I’ll find out when it shows up.
Your build sheet @OfficerDirtySanchez just posted in the Crowdsourced VIN Tracking thread shows you have power folding tow mirrors! :cool:
Sheet 6
Laffin’, checked this AM and didn’t see it, thanks.
Interestingly, I noticed this entry in your build sheet. I've not been reviewing others very closely but this caught my eye since so many people have talked about moving to D1 status but then back to D.
On that same page are these other interesting entries:
I also thought "All Vehicles W/Power Mirrors" was an interesting entry. Might suggest that's a critical component and factor in scheduling.
I noticed that as well. I wonder if a simple feature such as that is causing a greater impact on the chip shortage scheduling than other things we figured.....
Can’t be anything to do with scheduling or chip shortage. My 2017 equipment listing has “all vehicles w/ power mirrors” and “all radio equipped vehicles”.
Don't all mirrors have power adjustment of the mirror/glass portion? Power folding seems to be the optional feature selectable in packages
You can get a tradesman with no power windows, door locks, and mirrors.
Just placed my order for Carli pintop 3.25 factory air ride lift. It’s on back order several weeks so we’ll see if it arrives before the truck…..
