I didn’t notice any difference after installing the 325s... just speedo a little offThanks, truck looks great.
I shouldn't have an issue with the 285-75's being the same height as yours but narrower.
Did you notice much difference running the taller tire versus stock?
Are you planning on a level or happy with stock suspension?
Cool, I ran that size "Nitto Terra Grapplers" on my 2008 Ram 2500 Mega Cab with stock rims but It had Kore level kit. The tires fit the stock rims great and rode nice.I'm planning to run that size when my truck comes in. From what I've read, the reports are that it should fit on the stock rims with no rubbing.
Since @g00fy posted a side on pic of stock wheels, I’m assuming you’re asking for a straight down the side pic from the front/back. I can’t help you with that, but the 285s are only 10mm wider at the sidewall than the 275s (that’s ~3/8”) so just a little wider rubber on a stock wheel.Hi guys. Looking into the 285 75 18. Anyone have a side view pic? Just wanting to see what they look like with stock offset.
I have a 2021 Cummins and was wondering if the is significant power loss? Thank you.
Hello, new to the forums. How do you like your 285 75 18? Any significant power loss for the Cummins?Running 285/75R18's all stock. No rubbing or anything, the truck makes them look kinda small.
