That is a cool tool thanks for taking the time to put in numbers
Gearing Analyzer with Shift Tracer
Enter gear ratios, tire and diff ratio to analyze RPM vs velocity at shift points with tracer
View attachment 16309Aisin with 4:10s
I should also add that the Asian trannies are generally sexier than american trannies.I'm happy with my regular tranny. I'm understanding that the Asian trannies are more durable, and can handle a bigger load. Whereas the American trannies are a smoother ride. I don't abuse my tranny so it should hold up ok.
Awesome truck. I'm still glad I have the SO, due to the narrower hips...
Howdy. I have a 2021 Standard output 3500. It is extremely quiet. The manual doesn't say anything about having to adjust the valve lash at 150k. I have done extensive searching online and on this forum and I cannot find a definite answer to the following question:Watch this video: Here's how the Cummins Diesel in the 2019 Ram HD Makes a Huge 1,000 Lb-Ft of Torque! Here is a summary of what's stated in the video:
- The HO block is made out of Compacted Graphite Iron (CGI) material which is stronger.
- The crankshaft is strengthened.
- Stronger main bearing caps with larger bolts.
- The flywheel has 10 bolts for increased strength. The previous version had 8 bolts.
- The flex plate is thicker and stronger.
- The damper at the front of the engine has been retuned.
- Increased the diameter of the piston pin and the bushings.
- The cam is now a hollow billet cam.
- They added a scissor gear to the front for Noise, Vibration and Harshness (NVH) control.
- Hydraulic lash adjusters. This means there is no longer a requirement for overhead adjustment.
- An "enhanced" turbo charger.
- Bosh CP4.2 fuel pump to increase injection pressure. [This pump is controversial]
- It is 60 lbs lighter
- The maintenance interval on the breather filter has gone up to 75,000 miles.
- The anticipated life of the engine is such that at 250,000 miles 10% of the engines will need a rebuild and at 350,000 miles 50% of the engines will need a rebuild.
- A more efficient cooling system to handle the higher heat
- Increased cylinder pressure
Watch this video: Rod Romain explains the differences in the HO. Here is a summary of what's stated in the video:
Cummins' web site states states these improvements:
- They increased the strength of the connection rods by going to a higher strength alloy.
- They increased the strength of the crankshaft by going to a higher strength alloy.
- They switched to a Compacted Graphite Iron (CGI) block.
- New heads.
- The turbo was improved for airflow (primarily on the compressor side).
- The fuel pump is a new high pressure pump [Bosch CP4.2]
- The injector lines were improved.
- The engine water adapter and water outlet are both made out of aluminum instead of cast iron to save weight.
- They went to a hydraulic lash adjuster. It is quieter, and it doesn't require a rocker adjustment at 100,000 miles.
- Overall, the weight was reduced by 60 lbs.
- They beefed up the Aisin transmission. The shift schedule was improved [this is controversial].
- They beefed up the transfer case.
- The front and rear drive shaft joints are larger, and they went to more of a CV-style joint with a slip-in spline. It is "more robust."
- They reduced Noise, Vibration and Harshness (NVH) control with new dampers.
- The exhaust hangers were redesigned.
- A Compacted Graphite Iron (CGI) material for the block allows us to increase the cylinder pressure capability while reducing the overall weight by almost 60 lbs
- A new cast-iron cylinder head containing high-temperature capable exhaust valves actuated by all-new hydraulic lash adjusters in the block eliminates the need for valvetrain adjustment service intervals
- The heart of the engine is a higher-strength alloy crankshaft with a 10-bolt crank flange driving newly-designed forged connecting rods and new bearings which transfer power from the low-friction ring-wrapped pistons
- A new larger Cummins Holset variable-geometry turbocharger optimized with heavy duty bearings, and a new compressor-side housing is a key ingredient in the new ratings, pumping 33 pounds per square inch (psi) of fresh air into the engine
- The new fuel-delivery system includes a new 29,000 psi (2,000 bar) fuel pump and fuel rail with Cummins Filtration “filter in filter” NanoNet® technology
As @brutal stated, the HO engine also comes with the 12" rear end (code AAM).
Does the standard output have a CGI block? And hydraulic lash adjusters? Hollow billet cam? Anybody know for sure one way or the other?? Thanks in advance
Thanks HO. How about the strengthened flywheel? Main bearings and all that?19+ RAM Cummins diesel trucks are all CGI and use hydraulic lifters.
| VIN: | 3C63R3RL6LG14xxxx | 3C6UR5FL5LG298347 | 3C7WRLEL4LG220684 |
| ESN: | 59326xxx (HO) | 59402531 (SO) | 59364831 (CC) |
| 2020 RAM 3500 | 2020 RAM 2500 | 2020 RAM 4500 CHASSIS CAB | |
| Engine code | ETM | ETL | ETN |
| PART | |||
| tappet | 5475112 | 5475112 | 5475112 |
| camshaft | 5404088 | 5404088 | 5404089 |
| piston | 5342939 | 5336393 | 5336393 |
| complete head | 5340171 | 5340171 | 5405018 |
| bare head | 5340169 | 5340169 | 5405016 |
| long block | 5476081 | 5476081 | 5476082 |
| crank | 5342937 | 5342937 | 5342937 |
| Turbski | 5456365 | 5456365 | 5456365 |
| injector | 5289266 | 5289266 | 5289266 |
Thanks for the links and info! I think it's part of Cummins marketing to not state outright that the engines are essentially the same. They always make it sound like the HO is more robust. But it makes sense not to manufacture two greatly different engines and camshafts, flywheels etc.The engines are identical except for what is believed to be a head design due to the difference in compression between the SO and HO. I don't recall if anyone has been able to verify part numbers for the heads. It's entirely possible it's just a thicker gasket. It's also possible it's different pistons. I don't recall that anyone has fully vetted out the differences.
The HO gets more boost, so different programming in the ECM.
If you're basing any info off the TFL truck video Andre did, it's full of misinformation. many of the online reporting is incorrectly conflating the HO as being "different" and the new CGI block, leaving out the fact that both are CGI.
The engines are within 1lb of each other, that should tell you something.
Cummins 6.7L Turbo Diesel (2021) | Cummins Inc.
In 2019, we celebrated a 30-year partnership with RAM truck that started with the Cummins 5.9L Turbo Diesel in model year 1989. The 2021 6.7L Cummins Turbo Diesel brings to the table even more horsepower and torque while maintaining the diesel’s historic durability and efficiency.www.cummins.com
Cummins 6.7 Turbo Diesel Unveiled in New RAM Heavy Duty at NAIAS 2019 | Cummins Inc.
Cummins Inc. unveiled its next generation 6.7L turbo diesel engine boasting a first-in-class 1,000 pound-feet of torque.www.cummins.com
Next Generation Cummins 6.7 Liter Turbo Diesel is First to Deliver 1,000 Pound-Feet of Torque | Cummins Inc.
Cummins Inc. (NYSE: CMI) unveiled its next generation 6.7L turbo diesel engine boasting a first-in-class 1,000 pound-feet of torque. In addition to an increase in torque, the engine also has a higher horsepower output taking the 2500 and 3500 heavy-duty RAM pickup truck customers to the next...www.cummins.com
Bigger injectors too from what I heard.The engines are identical except for what is believed to be a head design due to the difference in compression between the SO and HO. I don't recall if anyone has been able to verify part numbers for the heads. It's entirely possible it's just a thicker gasket. It's also possible it's different pistons. I don't recall that anyone has fully vetted out the differences.
So I want to add some more standard vs HO info. I bought a 2021 3500 HO (white). My father liked it so much that he went out and bought a 2021 2500 (gray). The two are very similarly equipped.
You can definitely tell a difference between how the two drive. Casual driving mine is more laid back, it doesn't really care what you do. The 2500 feels more... urgent? I guess is the right word. With that being said, you can definitely feel the power difference between the two.
As far as the transmissions, mine goes through the first few gears way quicker than the 68rfe. Jumping between the two makes me feel like it takes forever for the 2500 to make it through 1,2,3. The Aisin definitely shifts with more authority and firmness. I much prefer the Aisin over the 68rfe.
The 2500 gets better fuel economy. Stock for stock, I was getting between 17-18 on the highway while he's getting 20mpg easy. Both sit at the exact same rpm cruising 80mph.
Also to note: the exhaust brakes.
In mine you can definitely feel it slow the truck down... it works really well and I love using it all the time.
The 2500 barely makes a difference with it on or off. You can hear it but that's about it.
