Surf2snow1
here’s thuren’s spiel on their sway bar:Is that stabilizer something that would also benefit a completely stock truck at all?
Our Active-Rate sway bar is a softer spring rate compared to the stock OEM unit, allowing the axle to move and articulate more independently, side to side. This softer rate smooths out off-camber bumps, pot holes, curbs, etc….
There’s more to read prior to buying one (cautions on when not to use one):
2014-2022 Dodge Ram 2500 High Clearance Active Rate Sway Bar
The Thuren Active-Rate Sway Bar is a softer spring rate compared to the stock OEM unit, allowing the axle to move and articulate more independently, side to side. This softer rate smooths out off-camber bumps, pot holes, curbs, etc.
