Have a line on a maintenance item or accessory discount?
Had a great experience with a vendor?
Post em up.
Post em up.
I always buy my Husky mud flaps/guards that way. For whatever reason, they always have them available in the warehouse for super cheap.Just a quick tip for everybody. Before you buy a part or accessory, get on Amazon and go to Amazon Warehouse. Search for the item in the warehouse search bar. Don’t use the predictive text in the search, it by default makes the search in normal section. Anyway, a lot of times you can find items cheaper. It will give you a general description of what’s wrong with item. Most of time, it’s something someone has ordered, unboxed, and returned. For example, I bought a set of tie Rod ends for my Rzr, for $30 less than new.
Also like the thread...I just don't see 50% off on this item, what am I missing?
Ryobi 1600 PSI pressure washer for $68 at HD. Great unit for light house duties. Works great with a foam canon if you swap out for a 1.1mm orifice.
Note: It wouldn’t add to cart on my phone, but was able to purchase on my PC.
YMMV - It wasn’t available for awhile, but then showed back in stock. May need to keep checking.
RYOBI 1600 PSI 1.2 GPM Cold Water Corded Electric Pressure Washer RY141612 - The Home Depot
The RYOBI 1600 psi Electric Pressure Washer features a light-weight, portable design with on board storage for user convenience. It is great for use on bikes, campers, grills, patio furniture and manywww.homedepot.com
agency6.com
