ramblinChet
Drinks Alone
delete
My ARB single compressor had 1/4” NPT fittings ...maybe it’s just the twin that has BSP fittings? The arb quick connects also used 1/4” NPT but I recall seeing they had a BSP version as wellOne thing to note about ARB is that they primarily use BSP connectors, i converted them all to NPT to make all things equal and ease of getting replacements.
Looks like a beast of a compressor! Excited to see your build!Today I decided to place my order for my onboard air system. The ExtremeAire Magnum compressor and several accessories were included in my order.
Specifications
It comes with a 7' heat dissipation hose
High temperature check valve
145 psi pressure switch
12 Vdc 100 amp relay
12 Vdc electronic blow-off valve
