View attachment 205602 year old 53k 1500 Laramie. I don’t rake great care if my truck and I use it for construction and a lot of outdoor activities. Suede looks brand new.
That's the passenger seat....someone doesn't need to sit there when the truck is rolling....show us the driver seat...where someone MUST always sit....and if it looks that good it will be amazing!
So I went through the google sheet just now and checked every VIN. The only builds that populate the buildsheets currently are Tradesmans. Most with SO Cummins, only a couple of the tradesmans with HO populated. The rest did not. Looks like they're building out Tradesman orders first.
You should create hyperlinks so when you click the VIN it directs to the build sheet page.
OK this is a over hill but I have been reading all the posts and seeing so many conflicting things.
So I contacted RamChat as seen below just to see their responses
And yes they seem to tell you somewhat what you want to here.
So here is their responses for the last couple of days.
8/9/21
Thank you so much for holding. I am showing all of the materials needed to start the build process have been received. The vehicle should be entering the build process shortly.
8/10/21
I do apologize we do not have access to the codes
8/11/21
The vehicle should be entering the build process very soon.
8/12/21
The Ram is in the scheduling stage waiting for all parts to be available and for the 2022 production to begin. At this time we do not have an estimate for when the build will begin, so I'd recommend contacting back towards the end of the month for a new update check.
8/12/21
All of the materials needed to start the build process have been received.
8/14/21
Thank you, The 2022's have not started production as of yet. I can see your order is in the scheduling stage, once all of the required parts for your order are accounted for it will be sequenced for production!
It looks like a lot of trucks that were D1 with early ship dates (mine was today), did get pulled. Sandi let me know I’m now D. At some point the estimated ship date did get moved to 8/11 though…guessing if you were D1 and Ram tells you they haven’t started building 2022s yet, that’s probably why. You got moved back to D.
I just received an update from Sandi that mine was one of the trucks that went from a D1 status to a D status but still shows a ship date of today. I'm not certain where this puts me in the mix but by the sounds of it I still have some waiting to do
I placed my order July 5th for a Laramie 2500 Crew Cab. If I’m managing my expectations…am I off my rocker to hope for a Nov delivery?
What's your VIN? There were probably ~25k orders in for 2022's around July 5th. Assuming they have production ramped up and are cranking out ~750 trucks per day, That would put your truck about 33 days out from 8/9 for being built. Then 5-6 weeks for shipping. I'd say early Nov is very best case probably. Maybe late Nov or early Dec.
There are other factors in play, that's just a very simplified break down and lots of speculation :)
Good morning all, I had a few moments this morning so I ran the report again and here's the VINs that populate the build sheet tool. Some of the VINs that populated last night don't as of this morning, presumably because they were kicked back to D from D1.
3C6UR5CL9NG117404 - 2500 Tradesman CC 4x4 6.7SO
3C63R3RL6NG100390 - 3500 Limited CC 4x4 6.7HO
3C63RRGL7NG100534 - 3500 Tradesman CC 4x4 6.7SO
3C63R3GLXNG104736 - 3500 Tradesman CC 4x4 6.7HO
3C63RRGL4NG107196 - 3500 Tradesman CC 4x4 6.7HO
If you only submitted the NG order number my tool won't pick that up to check. Update with your full VIN if you can.
Thank you! I know I have a VIN and it’s queued for production (as per sales guy). I just need to get the actual numbers from him :-)
That's great thing you have there! Kudos for coming up with it.....not to break stones but the first and last vin's are the same.
