Tow/haul traction switch options
Hold on.... You mean there is a switch that has the piano style buttons that is a direct swap?... Is there one that has the tow haul, diesel exhaust brake, and aux bank? If so those aux buttons would be a lot easier to label than the standard push button ones.
You would need a lot more than just the aux switches to be able to use them
Yes, the switch bank with the aux switches will work in place of your current switch bank. Obviously, the aux switches won’t function unless you add some other stuff and program them, but the top row of switches (that have the same functions as your current switches) will work normally. It is a direct plug n play swap. Let me know what switch functions you currently have, and I can find the aux switch bank part number for you.
Were you able to come up with a part number for just traction off and tow/haul?
Thanks for your help!
I already have the aux switches, but there is no good way to label them and have it look decent. The piano style buttons though are a lot easier to label.
ah i get you, but the piano keys are only for the trucks without aux switches…
This appears to be the part number, but between catching some that I know are incorrectly described, check this part number against this VIN with any dealership parts department- 3C6MR5AJ5MG607435
68476018AB
68476018AB
Thanks a bunch ! ! !
68476018AB
This is definitly the right part, I went to my local dealer and they verified with the VIN. Install was amazingly easier, not certain how many (if any) of the switches will actually do anything, as my plug had a lot fewer wires! I thank you, my lady's knees thank you!
$174.25 !!! Worth every penny !
The 2 original buttons will be the only ones that work
