I marked my housing before taking it in. When I picked it up, no marks were there so it was replaced.
Wish I would have thought of that before taking mine in. That would have been too easy!
Really? I don’t feel anything. Maybe mine are messed up..Agreed, my vented seats blow cold air from the A/C. My butt gets cold after a little while.
Sent from my ONEPLUS A6013 using Tapatalk
Frustrating for sureI took my truck in for regular service, leaking third brake light and I mentioned the AC issue as mine is about 12 degrees colder on the passenger side. I pick my truck up and the tech has noted, replaced fan blower due to low volume and blower getting hot during operation. I asked how does that fix the temperature difference and told the guy there is a TSB all about this. He said I needed to make another appt for them to look into it more, see if there was anything for them to do or parts to order, then make another appt for them to actually fix it. On a side note, I dropped my truck off on Monday evening for a 11:00 appt on Tuesday and picked it up, on Wednesday at 3:00 and it was still in the service bay. Two more appts after you had my truck for two days, sheesh..
The seat vents only blow whatever the ambient temp is in the truck... you can try turning on the floor vents (there is one under the seat blowing into the back) to pull cooler air up through the vented seat.
I could be wrong, but I am 95% sure the vented seats pull the air though the seats, not push. They are pulling warm air away from your body.
I'll have to fart next time I get in to check. I just ask the back seat passengers if they smell anything.I could be wrong, but I am 95% sure the vented seats pull the air though the seats, not push. They are pulling warm air away from your body.
and that was opening all the window to 'air out' the truck and driving the whole way with MAX AC on
call ram customer care and bitch (female dog) like crazyI brought my truck to my dealer yesterday for an oil change and asked if they could perform the TSB because I had really really poor AC performance in the desert on a recent trip.
They completely refused to perform the work. They tried out the AC (it was 65 out) and said that it worked fine and blowed cold. I was driving the same route in my 2000 GMC Sierra 1500 with 210k miles and its 20 year AC performed much better than my 1 year old $65k truck.
Any tips that worked for you guys of how to convince them to fix the AC? I printed out the TSB and brought it to them but they completely ignored it.
Today's drive home in Flori-duh... post TSB 'fix'
98 degrees, "feels like" 103, humidity is a low 50%.
I was only hot/uncomfortable for about 2/3rd of the way home...and that was opening all the window to 'air out' the truck and driving the whole way with MAX AC on.
I guess it's an improvement from simply being hot/uncomfortable all the way home... and it isn't even August yet.
But my new Borla sounds nice...![]()
