How to upgrade the open space below the radio with a drawer.
My truck has the inverter plug. There are two version's of the drawer, one wirh the inverter plug and one without.
Parts needed: instrument panel drawer with inverter plug - 6NK25TX7AB, instrument panel bezel with slot for drawer button - 6RP72TX7AB.
I only needed a flathead screwdriver to swap over the inverter plug and USB ports.
You will reuse the lower trim bezel that goes over the center hump.
First, remove the lower trim bezel.
Then remove the bezel surrounding the open cubby. Only held on wirh clips so it pulls right off.
Then remove the cubby. It's held on with the same type clips.
Unplug two connectors from usb and one connector for inverter plug.
Here are the 3 parts removed.
Here is the new drawer and bezel.
Use flathead screwdriver to release tabs on usb and inverter connections.
Install into new drawer.
Go ahead and install bezel surround to drawer to make sure all clips go in correctly.
Plug connectors back in and reinstall.
