Pressure in coolant system pushing into expansion tank
Mbeavers
Aug 7, 2022
Hey everyone I need some help. I’m afraid I know what’s wrong but keep denying it. I have a 2012 6.7 Cummins HO. Fully deleted and getting pressure into expansion tank causing antifreeze to move over and not come back. Causing coolant system to be starved of coolant. I have changed thermostat, radiator cap, and pulled water pump and checked it, passed combustion test, also flushed what lines I could except the radiator.
All this started after the bypass line going to riser pipe failed. Could it still have air?? Or going to be head gasket
The times pressure or how much coolant moves and temp it runs varies. Nothing is consistent to tell me I have a head or head gasket problem. I have a 15,000 fifth wheel. I can hook to it go 5?miles have to move antifreeze back then roll 200 miles with no problem with temp running 197 to 212. Then pulling empty will do same thing. Is this for sure signs of a gasket problem. All help is greatly appreciated it’s a head scratcher
Ohhh yeah it’s running a H& S mini max with 80 horse tune I believe
get some combustion test strips to see if there is combustion gasses in the coolant it could be just a need for head studs or it could be the head gasket
Gear box
Dec 25, 2021
Google-“bubble test for Diesel engine”
When you do this test- engine must be up to temp and may have to raise RPM up. You can also have scanner on engine while testing and cut out cylinders to see any changes.
Good Luck!
Gear box
Dec 25, 2021
This is also called ”bottle test for Diesel engines.
snopro
Jul 12, 2023
Time for studs...head gasket .. good thing your pushing from the cylinder to the coolant passage...could be worse and be blowing it to the oil pan...
He said it passed the combustion gas test so no its not likely the HG…
snopro
Jul 12, 2023
So did mine...would only pass to the coolant bottle when you got on it for passing gear in performance mode...and when the turbo brake put back pressure on the cylinders...other than that, if you just drove it normal everything was peachy...
I have yet to see one that the combustion strips did not pick up combustion gasses when it only happened in the manner you describe.
snopro
Jul 12, 2023
I'm sure you'll educate me then...
Im just saying i have never seen it never said it was not possible but perhaps something else was at play like bad test kit or something….
compassstowingnw
Jul 16, 2023
I have the same problem going on but I have already put on a from Cummins reman Head and gasket with ARP installed, mine started as a bad EGR cooler that was replaced to then having coolent being pushed into the overflow bottle. Fails blue water battle test when its hot. put pressure gauge on radiator ran extra hose into cab and drive come to find that its not building pressure under boost but when it comes to a idle while making a turn or stopping at a light or sign, with out without the exhaust brake on. any help might save me from pulling the trigger on a long block tomarrow.
Cooters-Garage
Nov 25, 2023
What did you find out here?
snopro
Jul 12, 2023
snopro
Jul 12, 2023
Your feelings are correct... it's time to put a head gasket in...make sure you install head studs so you won't have to do it again..stock stud the weak link...
You tried to tell him the same info 5 months ago….
snopro
Jul 12, 2023
Well..what can you do... it's not an easy job... especially if it has all the emissions on it... you're already having to stand 2 ft.off off the ground crawling halfway into firewall...bent over ...especially if you don't have a extendable boom cherry picker and building yourself a special lift adapter to keep the head controlled level until the rad support...if you're a decent wrench it still takes the better part of a weekend to do the job... baring any head work...
Its a pretty easy job actually just a bit time consuming but thats not what i meant lol
