Power Wagon Tonneau Cover
wyvern
Aug 18, 2023
Hi gents. Anyone have a recommendation for a good strong waterproof tonneau cover for the power wagon? My bakflip hard fold leaked so bad I sold it. Just trying to keep gear from the elements.
Soapy
Jul 9, 2022
Every cover will leak to some extent. I know a local shop that has been doing covers for years and they say that a soft fold cover or a soft one with velcro along the sides tend to be the driest. I have a Bak X2 Revolver cover and I think it seals as well as any I have had, soft or Hard. The revolver lock mechanism pulls the whole thing down along the side when in use so I think it gets a better seal that a trifold that only clamps down in a few spots.
Iowagon
Feb 16, 2021
Cedar Rapids
Do you have ram boxes? My neighbor has a Diamondback on his F-150 and claims it doesn't leak. My Diamondback leaks at the corners of the tailgate but I think that's because of how it mounts inside the bed because of the ram boxes.
wyvern
Aug 18, 2023
I do not have ram boxes. The Diamondback HD looks cool, but it feels like you're giving up a lot of bed versatility?
MtnRider
Feb 5, 2020
Georgia
Like mentioned, every fold back, roll back, flip back etc type cover is going to leak some. I've had several and they all leak a little. I think the only way to get a true waterproof cover is one that is a solid raise up design?
wyvern
Aug 18, 2023
trust me, I've had a bunch and they never leaked like the bakflip. I actually had them replace it under warranty and then reinstalled it again only for the same bulkhead corner leak to reoccur by the drain tubes.
I'd like something ideally theft deterring but would prioritize keeping gear dry over a harder cover. Maybe velcro/soft rolling is the move then based on comments here?
rjmlakota
Dec 6, 2023
WNY
I have a 2023 PW with ramboxes and the Diamondback HD. I just bought this tailgate sealer kit and will be installing the next time the weather is above 55. I'm hoping this stops the leaks. I do not get any leaks with my Diamondback HD. My bed leaks from the design of the ramboxes and tailgate.
DrTron
May 3, 2022
I have a MX4 (with Ramboxes) and it's the same as the previous ones. No leaks in normal conditions, but of course, when it pours or in the car wash, I get a little water in there. Like others have said, part of the design.
But it's never enough that stuff in the bed would be drenched or anything.
Pasta4lnch
Oct 12, 2023
Lawn Guyland, NY
fwiw I'm on my second Truxedo Centry CT and, while they didn't exactly leak - I still got water in and I think it was from the gaps by the tailgate - nothing to do w the cover. I thought this would be a huge PITA but I bought bins and anytime I travel w stuff I dont want to get wet I just throw it in a bin, usually uncovered as the water just pools at the bottom (including electronics and luggage). It's actually kinda better. Organization and I put string around them and tied to ties at the tailgate so I can pull anything out that slides up without having to hop in. (laziness is the Mother of invention!! :p )
Soapy
Jul 9, 2022
My BAK is a roll up hard cover that rolls up on top of the bed not into a pocket mounted in the bed. I do get very little leaking with it.
wyvern
Aug 18, 2023
I have an Access from Agri-cover and love it. It's a rollup style and the only time I see water is near the tailgate after a car wash.
I feel like this is my best bet until I feel like spending bigger amounts of cash on stuff for a dedicated camping setup.
wyvern
Aug 18, 2023
Crazy how waterproof this cover is. Drove through some crazy storms and two car washes and it’s bone dry back in the bed.
Docwagon1776
Oct 29, 2022
I've used multiple Tonno-Pro tri-folds. As long as you use the supplied tailgate gasket and clamp it down tight, little to no water infiltrates into the bed. The downside is the stitching wears out over the years, but they will warrantee it once it gets bad enough the vinyl starts to come loose.
wyvern
Aug 18, 2023
Hey @Wobly, does your Access have any of the excess tensioned vinyl material chilling out along the bulkhead area or did you tuck that small excess into the bed?
Fantastipotamus
Feb 15, 2024
Howdy - any update on this? I'd looked at a few tailgate seals on realtrucks but didn't pull the trigger on one yet. Does it interfere with the tailgate function (Meaning- is the seal tight enough that the tailgate can't unlock without being pushed in a little)? My 1500 i traded for my 2500 I had to push the tailgate in a little or it wouldn't unlatch, which I'm hoping to avoid.
FWIW on this thread, I had the Truxedo Pro X15 on my 1500 and really liked it, enough I bought another for the 2500. Like the matte cover finish, the very low height, fits tightly, is reasonably water tight, and.. semi secure? Last one was on since 2018 and the "velcro" around the edges still held perfectly.
