Diesel tank upgrade
MEGA-HO
Apr 17, 2021
I’m planning a 2021 limited longhorn mega cab 3500 srw with the Aisin high out put Cummins. Am I able to get a bigger tank then what I believe is the 31 gallon tank? I’m ok paying more for that upgrade and not doing it after market. Thanks
Will_T
Jan 23, 2021
Southwest Oregon
I believe if a long bed you have the option for a 50 gallon tank from the factory. I ordered a standard bed so will be having a Titan 52 gallon replacement installed. There are other manufacturers also and some long threads here about the subject. Here is one example.
camaroz2866
Aug 2, 2021
I put the titan 50-52 gallon under my 21 megacab and then used Alfaobd to adjust the tank size so the dte reads correctly.
If you get the MCSB your SOL for OEM if its a CCLB you can get the 50 gal tank OEM…. Anything else would be aftermarket
John Jensen
Feb 11, 2020
Not an option on the Mega, is only an option for an 8' bed
Your only choice is aftermarket.
jetrinka
Jun 11, 2021
Aftermarket. My father had a Titan Tank unit in his 16 F350 we installed and it works great
